Thread: Help, radio cage wont fit fascia adaptor
    Nov 2010
    Maidstone
    Default Help, radio cage wont fit fascia adaptor
    I recently bought an Alpine INE - S900R for fitment into my vauxhall signum, now the double din unit fits in the apature fine, but when you try and slide the genuine alpine cage into either a connects2 or autoleads fascia surround its too wide by about 5mm, can someone help cos im in right stook. Initially i bought a connects2 facia kit (including cage etc), now that cage fitted the radio fine and slides into fascia adaptor fine but these cages are so cack none of the prongs will locate in the dashboard so it moves all over the place. Help
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    you have to buy a full double adaptor kit which comes with a different cage also
    Nov 2010
    Maidstone
    As said in first post, i did buy full cage kit from connects2 but the cage supplied is a bit pants, can hardly bend any of the lugs round so it still moves alot, the alpine cage that come with the radio is unnecessarily wide, doesnt make sense, would show a pic if i could. Dont know what to do..
    Feb 2007
    ahh sorry didnt read the last bit!! mine fitted perfectly in the supplied cage it was the fascia that was a bit loose. have you screwed the extra brass fitments on the sides that lock the stereo in the cage?? i could bend the lugs fine in mine could really do with a pic
    Woodbridge
    Had to use the connects 2 cage too then add the fitments as above, it all fitted perfectly then, The kenwood cage would not fit mine either
    Nov 2010
    Maidstone
    Did you have to do some adaption of the plastic unit which holds the cage in the dash, can see me having to dremel some holes for the lugs to go in??
    Woodbridge
    No mate it was all standard fit, no drilling or cutting!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Fitted my Alpine double din (IVA-W505R) straight away with no issues with a double din fitting kit. Honestly can't remember whether it was a connects2 kit or not, but pics are here if it helps.
    http://www.vectra-c.com/forum/showpo...4&postcount=62
    Feb 2011
    Kent
    How did you get the old radio out? I am having real trouble with mine - can't get it to budge and have now dismantled half the car!!!
    Feb 2011
    barnsley
    The stereo came out of my Vec easily enough with a pair of stereo removal tools. Just happened to have a pair from when an aftermarket instal in my sis's Corsa!!
    Just pushed the tools right into the removal holes to release the tabs then just pulled the stereo out with them!! Then the cage just needs to have the screw removed from the back then the cage can be wiggled out!! I did however lose a bit of skin off my fingers doing this part as the cage is sharp in places!!
    I bought a double din adapter off ebay for about £8. The cage from my Alpine CDA-9886 fits perfectly fine!!
  1. Radio cage and signle din fascia
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2012, 12:50
  2. Radio Fascia Adaptor & Canbus adaptor
    By PeteRs in forum Parts for sale
    Last Post: 11th April 2008, 14:09
  3. Fascia Adaptor
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2006, 17:41
vectra c fascia adapter
vectra c 2005 facia kit
vectra c half din facia
vauxhall corsa radio cage
pioneer avh 270 cage wont fit in corsa c
how to fit fascia vectra c
cant fit my double din stereo cage vectra
radio fascia
zafira head unit facia dont fit
vectra c double din fascia
sph da120 fitting into vectra c
double din cage
vectra c radio facia
vectra c radio removal cage
aftersales head unit wont fit in corsa d
bought radio cage amd it dosent fit
double din stereo cage wont fut
how to fit double din cage corsa d
vectra c age
https:www.vectra-c.comforumshowthread.php129146-Help-radio-cage-wont-fit-fascia-adaptor
double din into vectra c doesnt fit
corsa. d. pioneer. radio. cage
can I fit up date car radio in vectra c
vectra c alpine double din head unit upgrade
cage wont fit in corsa d
