Results 1 to 10 of 18
Thread: heated wing mirrors
    newport
    Default heated wing mirrors
    are they both supposed to be heated? only my drivers side one gets warm, its a 2003 1.8 active
    Regular Member Steve01's Avatar
    Aberdeenshire
    Yes mate they should both work
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes both, as said earlier.
    newport
    do they work from the same fuse? any common problems that stops 1 working?
    11 Post(s)
    Yes the door mirrors both use the same fuse.
    Has someone changed the passenger door mirror at some point and didn't fit a heated one?
    newport
    possibly, i know that its had a hit at some point as the blue part on the top is cracked and the black plastic piece between the actual mirror and the car is cracked aswell, might have damaged the heater part with the impact?
    was looking at replacing it at some point anyway, so not overly concerned
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Pop the other one off, chances are the cables not been attached.
    newport
    is it a seperate plug to the adjustment motor, as that works fine?
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Its a seperate cable, thinks theres 2 actually, for the heater element.
    11 Post(s)
    There should be two flying leads that connect directly to spade connectors on the back of the mirror - IIRC.
  1. wing mirrors!!
    By ross4705 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 22:47
  2. Heated wing mirrors
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 17:47
  3. Heated wing mirrors
    By Birchy63 in forum Bodywork & Interior
    Last Post: 6th October 2010, 13:49
  4. Wing mirrors
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 23:01
  5. Heated wing-mirrors?????
    By Adamdavi3s in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2007, 17:00
