Thread: Door Mirror Shakes
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Default Door Mirror Shakes
    When driving, the door mirror shakes and slightly distorts the rear view. On inspection it seems not to lock as securely as the other side mirror, it's as though the spring needs tightening up.
    Can anyone point me in the right direction to sort this out?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Someones knocked your mirror, probably a pedestrian. I have the same and it seems someone took a dislike to my mirror when walking by. Still intact but wobbles at speed. Havent taken mine apart yet but I am guessing something has snapped inside (probably a plastic retaining piece). Probably going to order a second hand one and use the internals if I can
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    Quote Originally Posted by luke4487 View Post
    Good point - Iv'e had a quick look and it seems that a moulded spigot that the part that swivels locks into is worn, it's at the front of the base unit. I'm going to see if I can drill into it and replace with a metal stud.
    Bordon, Hampshire
    Let me know how you get on please Was just thinking about this on the way to work this morning and reminded me to check on here. Whats the best way to get into the mirror? I couldn't think of the right terminology but moulded spigot sounds good to me I shall remember that one!
    Apr 2009
    nottingham
    I had the same problem sounds like the spot on same symptoms this was after someone knocked mine and all it was,
    was the glue that holds the glass to the plastic had cracked and was beginning to flake away.
    so i just used a couple of terminal screw drivers to gently pry the glass away from the housing cleaned it with some solvent and re stuck with plenty of superglue 5 months on not even a tremmor the heater still works too
    if i was you id try this before you drill anything because it sound so simmler
    Bordon, Hampshire
    Mines the whole unit casing included
    Apr 2009
    nottingham
    it may all feel wobbly but just give it a go and see its worth a look
    i took one of mine apart once, the spring is all one piece and cannot be tightened up. But what I did do was clean and grease it all and it stopped shaking after that and started folding in again!
  1. Door Mirror
    By EJJ150847 in forum Bodywork & Interior
    Last Post: 14th April 2009, 11:48
  2. Door Mirror Help
    By Elite Estate in forum Bodywork & Interior
    Last Post: 11th November 2008, 20:19
  3. Door Mirror Help Please
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2006, 21:46
