Thread: clutch fluid level? how do i check it?
    Jan 2010
    worcs
    Default clutch fluid level? how do i check it?
    Im giving my car a good going over and want to check the clutch fluid level as the bite is quite low.
    how do i check it as i cant see a resivoir anywhere??
    or does it share the same one as the brakes?
    cheers
    steve
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Same one as the brakes mate.
    Jan 2010
    worcs
    is there a master cylinder and a slave cylinder??
    which one is likely to be the cause of a low pedal bit on the clutch ?
    the brakes feel fine and have lots of power?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    if you look the clutch one is so small so look see if its low as it mite have air in it as its a silly thing to do pug have there own little pot thats my next mod as i hate it
    Jan 2010
    worcs
    can you explain that to me bangty? is it in the same area as the brake one ? or in a different location?
    Sep 2010
    in a box
    same as brake one look at brake one look at back of it theres a pipe thats your clutch pipe when they run low (mine did this) they drain the fluid from the back(theres dividers in there) and when to low it dont get to the back and so after a while you suck up air and can be hard to bleed the clutch so it may be low and you have sucked air in(i park on a hill and it never got to the back everytime i toped it up so after a while it drained it) if look in day you see what i mean if changeing master or slave buy a pot like whats on moterbikes or pugs as its a lot easyer to bleed when you do any job to do with clutch
    sorry mate im much better talking about it then writeing it so if that dont make sence let me know lol
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. How to check Power Steering Fluid level?!?!
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th January 2014, 19:14
  3. how to disable low washer fluid level
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2012, 13:54
  4. PAS Fluid level
    By Rob_the_Scot in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2007, 00:00
clutch fluid levels on vectra
how to check clutch vectra
vauxhall vectra c clutch fluid reservoir
opel vetra clutch fluid
clutch fluid vectra c
where to I put clutch fluid in vectra c
clutch fluid zafira
how to top up vauxhall insignia clutch fluid
where does clutch fluid go in a vectra
vectra c clutch fluid top up
how to test clutch fluid level in vectra
signum clutch fluid location
brake and clutch fluid reservoirs vectra
