Results 1 to 10 of 22
Thread: LEDS in Fogs
    North West
    Default LEDS in Fogs
    I just bought these LED LIGHTS for the front fogs
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280596888924
    They fit in ok as a direct replacement for the H3 Bulbs ,but they wont light up though I am not getting any warning lights on dash (maybe cause i fitted the fogs myself - garage wired them in)
    when i take the original H3 Fog bulb out i dont get any dash error either
    what could be the reason why they wont light,they only fit in 1 way onto the lugs????
    tata ta
    North West
    it sys this on packet .............
    Each LED Light has both positive and negative side, so if there is no lighting
    after installation. Please reverse the bulb around.
    how do that? they only fit in 1 way
    mumbles
    Quote Originally Posted by Silver Vectra C View Post
    hi there
    they mean reverse the polarity of the power
    instead of positive to positive and negative to negative switch the wires around
    i had to do this to mine and now they work fine
    North West
    so under the bonnet where the garage wired power from my sidelights just swop wires aound (pos to neg)that are going to the fogs cheers i give that a go tommorrow its dark now.roll on summer
    North West
    i just checked wiring and the fogs are wired to sidelights,there is a relay and then 2wires going to each fog unit.So if i cut the wires to the connector to the fog and swop them around would that be correct to do,i dont wanna fire under the bonnet,thanx for advice ta!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Yep Thinks Thats What You Would Do
    North West
    can i cut the wire near to the fog connector and rejoin wires with a connector block and cover with insulation tape as i cant solder ?
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    That won't last a single winter. Find someone who can solder and use heat sink to keep the elements out. If your in/near London I'll do it for you for a pint.
    scottish region
    Quote Originally Posted by Sierra2 View Post
    Better than a connector block
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    Default get some pics up
    pics of it all done
  1. leds do or I don't I
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2013, 20:38
  2. Leds
    By 1 hammer in forum Styling
    Last Post: 27th December 2012, 12:07
  3. LED conversion, How Many LEDS, Which LEDS
    By gurjsagoo in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2012, 20:44
  4. LEDs again
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 04:03
