Thread: Headlight adjustment dial
    Woodbridge
    Default Headlight adjustment dial
    Since fitting my HiD's on saturday, it appears I can no longer adjust my headlights up and down from the dial inside the car. They do not seem to move at all.
    I am wondering if I have knocked a lead out. If so, can someone please tell me where it is and what it looks like. A photo would be awesome.
    Also, how does it work? I am assuming it does not move the bulb but just changes the reflection in some way.
    Cheers in advance.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Like to know this too, only one of mine moves!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The motor sits inside each light, on prefaces its in a recess in the dipped beam section, on facelifts, it's behind the middle cover.
    It twists out like a bulb (bayonet style fitting) then you have to angle it slightly to slide the ball out of the socket that moves the light in and out you can then remove the motor and unplug it. Refitting is reversal of the above.
    Woodbridge
    Just had a look and I cant see where this motor is? Is it inside the dipped beam cover for a pre face lift? Or is it attached to the unit?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Actually thinking about it, that may be my memory failing, on the preface I think they're at the bottom behind the larger hard plastic cover.
    If you still cant find it, I'll try and take some pics later.
    Woodbridge
    Quote Originally Posted by Ian-Highlander View Post
    Ok cheers mate, I have had my hand in feeling around and cant seem to find it. I had a look on ebay to see what it looks like. I cant see it in there lol.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Obviously the ball joint points into the headlight so you see the back end of it (a flat squarish block) with a wire coming out of it. Grab it and twist like a bulb (carefully).
    Have tried to take a couple of pics but it's pitch black outside, not sure if this helps or not, its the block in this picture (have already removed the larger plastic cover at this point). This is the passenger side one looking down from above.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Image of what the motors look like off an ebay advert...
  1. Headlight Adjustment
    By Siggy08 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 19:05
  2. Headlight Adjustment
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 22:27
  3. speed dial adjustment
    By darko2301 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2009, 13:59
  4. Headlight adjustment
    By Bops in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2009, 21:39
  5. headlight adjustment
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2007, 16:49
vectra c headlight adjustment motor
