Thread: BTCC Engines
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Default BTCC Engines
    Not sure how true this is and sure someone can enlighten me, back in the day did the vectra's run NA 2.0 engines? But were producing around 300bhp?
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Yeah that's about right I think - turbos are not allowed except on diesels (hence the controversy surrounding the current focus) and the regulation IIRC was 2.0 litre max capacity... not sure how they drag the power out of the engine though, other than some form of tuning chips...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep the super 2000's were all 2 litre and produced 300 bhp
    Quote Originally Posted by 19CDTi View Post
    Under the new NGTC rules turbo's are most definatly allowed
    Specifications
    • Front-wheel-drive
    • 2-litre turbocharged production-based 4-cylinder petrol engine, producing approx. 300bhp with a 7,000 rev limit, 0.8 bar of boost and inlet-restrictor.
    • 6-speed sequential semi-automatic gearbox
    • Increased minimum length of 4.4m
    • Standardised width of 1875mm
    • 2, 3, 4 or 5 door – providing they share the same basic silhouette and dimensions as the 4/5 door saloon version
    • Fully adjustable subframe-mounted front & rear suspension
    • Larger wheels/tyres
    • Common major components to be utilised; such as ECU, gearbox, brakes, hubs, steering rack, fuel tank and etc.
    • Integrated front aerodynamics to incorporate radiators, cooling ducts and partial flat-floor to a given design parameter/dimension. Specified rear wing profile and size. Each car to be wind-tunnel tested to achieve similar aero equality
    • Increased driver safety
    • Stronger and more robust major components with full at-event parts supply service and support
    • Lower C02 emissions output than current
    Jul 2009
    Bucks
    Just makes you think with the some serious cash I could make my gutless 1.8 probably produce around 250bhp.... without a turbo or supercharger. It amazes me how they squeeze that power out and there limited to 8500rpm. I remember the old Seat's used to be diesel, its not as good as the old days how I remember it. Really tempted to get some tickets this year.
    For any of you fans out there was looking at the tickets for the Sunday for Donnington, they are £25 and there is a grandstand £10 ticket? Whats the difference bit confused.
    Jul 2009
    Perth, Scotland
    Specifications
    • Front-wheel-drive
    Woopsie my bad!
    spoons
    Guest
    I like all the new BTCC cars with the bonnet vents
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Rebellion8878 View Post
    Basic lump is the same as the 2.2/2.0t. You can buy all the bolt on parts but they used to run a sealed btcc spec ecu.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Seem to recall while on a tour of 888 a couple of years ago when the 3 vxr vectra,s were there that the engines had renault blocks
    and still loving it
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Actual spec for VXRACING 2009 RACE CAR - on ID tag given to those of us who signed up online for access to the VXR marquee and attended the BTTC round at Oulton Park in that year.
    Engine 2-litre N/A 4cyl 16v
    0-60 time 4.7 secs
    Top speed 150 mph
    Power Approx 290 PS/290 bhp @ 8400 rpm
    Torque Approx 260 Nm/191lb/ft @ 7000 rpm
    Weight 1140kg
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by bobssignum View Post
    Thats deffo the ecotec block mate. They did fit the Pig iron LEH as well. Spares available HERE
  1. what are the 1.8 and 2.2 engines like?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2010, 00:25
  2. C diesel engines.
    By Davedup in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 12:50
  3. Engines Differences (if any)
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 19:20
  4. 2.0T engines
    By oz1988 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2008, 19:15
  5. 3.2 Engines
    By Richard in forum Petrol Engine related
    Last Post: 13th February 2007, 08:32
btcc default engine
