Results 1 to 10 of 15
Thread: loss of power and sluggish
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : signum 1.9 cdti 150
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Default loss of power and sluggish
    hi all, im new to this site, ive got an signum 1.9 cdti 150 54 plate and over the last week my performance has dropped rapidly to were the car is very sluggish, in first and second gear with loads of revs but hardly moves, when up to speed aint too bad but still feels sluggish and feels restricted, ive had it dianosted and found nothing, no warning lights either. any ideas??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    First port of call is check the vacuum and boost hoses. Fail in that the EGR valve is jammed open. I would plump for the EGR personally as when it jammed open there aren't usually any warming lights on.
    Gazza4
    Regular Member corderz's Avatar
    Bradford
    Sounds like swirl flap linkage to me....oh dear!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by corderz View Post
    Good way to worry someone, if it may just be something simple.
    Gazza4
    Bradford
    Lol, it is simple, new inlet manifold!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I take it the £1 fix never worked then?
    Until it is actually diagnosed, look for split hoses. If it is the manifold it will be allowing boost to be lost through the swirl flaps. Split boost hoses usually cause heavy smoking too and this is also the case of a borken manifold depending on how the flaps have jammed shut, and the bearings aren't that bad as to allowing boost to escape.
    Gazza4
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    cheers for the replys, a friend had a look today whos knows his stuff and it baffled him, all the things he expected it wasnt, egr ok, etc, he then accused me of putting petrol in which i know i didnt, he thinks the last fuel was poor quality and we ran the fuel down as low as possible and went to bp and put some ultimate in and after about half hour all is back to normal, so fingers crossed!!! thanks again!!
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Default £1 fix
    whats this £1 fix i keep reading about on here??
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    same problem back, boo hoo, done new egr and cleaned boost sensor, changed air filter and done £1 fix, was fine for two weeks and now back to square one!!! please help
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by paul-west-76 View Post
    Have a look at the manifold. Better to check the others and eliminate them earlier.
    Gazza4
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Cdti lack of power engine sluggish
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 19th January 2011, 16:07
  5. Sluggish acceleration & power steering failure
    By grogsy in forum Engine & Drivetrain
    Last Post: 5th August 2009, 17:30
vauxhall vectra c swirl flaps loss of power
