Results 1 to 10 of 19
Thread: Using holts radwield on 1.8 petrol vec
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Using holts radwield on 1.8 petrol vec
    I think i may have a very small leak somewhere in the radiator or somewhere as im losing around half pint of water every two weeks or so, and when ive taken the car on a run and leave it n look under 10 min after theres always few little drips on floor under left hand side of radiator, maybe the cold spell in december had caused a small crack?? My question is does this sound common or like summet else or would it be worth giving the radwield a go and is this 100% safe to use, carnt block anything else up or anything? Thanks in advance
    Jul 2009
    The Rift, Cardiff
    Personaly I would not use radweld, i'd rather find the leak and fix/replace whats causing it. Radweld can block the heater matrix and other thin coolant pipes, imo its not worth the risk, but some people use it without any problems.
    As you have puddles it makes it easier to find the leak. I've had a leaking rad and expansion tank on my 1.8
    Sep 2010
    Leeds
    Well, where the small amount of water is on the floor i put my hand up and in etc and everywhere seems dry! Jus hope it is a little leak and nowt more serious, i think my thermostat may be playing up also as it takes ages for my car to warm up and stay warm when heaters are on, so maybe this may play a part in it.
    Glasgow
    I had to get a new rad fitted to my vec 1.8, £100 it cost supplied & fitted!
    Wouldn't touch radweld or anything similar personally!
    G
    Regular Member mccluskey119's Avatar
    gourock
    I'm having the same problem with my 1.8
    Its losing water every week, wouldn't touch rad weld either getting a new rad fitted on Wednesday
    gourock
    Sep 2009
    Audley STAFFS
    Rad weld will not help if you have leak on a hose or joint,, try to find the leak.
    Chelmsford
    Probably the classic rusty joint along the off-side of the radiator, where the metal meets the plastic.
    www.autokool.co.uk
    £50 and 45 minutes to fit.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I had a core plug gone on a cdti engine before,i used forte coolant stop leak,it worked a treat,as the core plug was behind the turbo
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by DNS View Post
    www.autokool.co.uk
    Can't recommend these enough.
    Had a radiator for the Nova Gsi, AirCon Condenser for my old Astra G and a radiator for the Signum from them. All arrived very quickly and fitted easily.
    I did a small write up how I swapped my rad in the Signum (no pics tho)
    http://www.vectra-c.com/forum/showpo...01&postcount=7
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. Bars leaks or holts new radwield???
    By Jow20 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2011, 15:47
  3. holts tyre repair
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 10:18
  4. OK. Holts Rad Weld, or Bars Leaks?
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 21:25
  5. Which Oil for the 3.2V6 petrol?
    By pswfps in forum Engine & Drivetrain
    Last Post: 3rd March 2007, 22:58
