Thread: 2006 Vectra In Limp Mode
    Feb 2011
    Midlands
    Default 2006 Vectra In Limp Mode
    Hi,
    Yesterday my Vectra 1.8 Petrol 2006 went into Limp mode which made the car very unresponsive when accelerating though does not cut out and can run the car at low speeds.
    The emission light on dashboard came on at the same time.
    I have had a independent mechanic run a diag and he in confident it is the
    ignition coil pack.
    Does that sound like the symtoms for a faulty Coil?
    Feb 2011
    liverpool
    Quote Originally Posted by PAULJG View Post
    Hi,
    ignition coil pack.
    That happened to me and it was o2 sensor
    Feb 2011
    Midlands
    whats the o2 sensor..Thanks
    Feb 2011
    liverpool
    oxygen sensor
    Feb 2011
    Midlands
    How much did it cost you to get fixed?? Thanks
    WGAF#5
    a coil pack can cause a misfire which would cause the engine to run poorly - to prevent significant and furhter damage the car COULD go into limp home mode..... did the garage give you a fault code ?? or just told you it was coil related ?
    Feb 2011
    Midlands
    It was a mobile Mechanic who spent 10mins with the car. I didn't get the fault codes
    Feb 2011
    liverpool
    cost me £400ish fitted but there are 2-3 reasons it would go into limp mode
    WGAF#5
    Quote Originally Posted by fluffy25 View Post
    there are more than 2-3 reasons why it would go into limp home mode
    air leaks, plugs, coil packs, fuel issues, 02 sensors etc
    if the mobile mechanic HAS read and diagnosed a coil pack issue and you paid for that diagnosis if he was wrong then i would be asking for a refund
    but as you initially asked - yes the fault could be caused by a coil pack
    Feb 2011
    Midlands
    Thanks. What quick responses. Great Forum. A least i know now that the coil could be possible causing the Limp mode issues. Thanks All. We update and tell you the outcome.
  1. Vectra 2.2 SRi (22se) EML on limp home mode
    By james chambers in forum Engine & Drivetrain
    Last Post: 4th November 2012, 20:52
  2. limp mode above 2500rpm Vectra 2006 120bhp 1.9cdti
    By mani911gt3 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:07
  3. Help Needed - 1.8 Vectra in Limp Mode
    By Kyser143 in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 21:33
  4. 2.0 DTi 03 Vectra - Limp Mode - Help!!
    By scrumpycider in forum Engine & Drivetrain
    Last Post: 26th August 2009, 21:57
  5. help limp mode on vectra 1.9cdti
    By signum junkie in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2008, 22:38
what causes limp mode vectra
