Results 1 to 10 of 13
Thread: Thermostat
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Thermostat
    Well need a new thermostat so the car's in the garage. Sat on 0 since the cold weather total coat £133 all in is this a good price. Also need a new ERG valve should get the price for that on Tuesday
    Wish me luck Steve
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    £133 for a thermostat?!? The part itself isn't anywhere close to that much! Can fit it yourself - easy enough to do. Mine's a 2.2 DTi and I had to replace the thermostat on that. Bought the whole unit from Vauxhall for 40 odd quid and fitted it myself. Took maybe 20 minutes?
    Save the money!
    East Midlands
    Quote Originally Posted by cont1204 View Post
    Save the money!
    Saved you even more if you had bought one of these.
    PRESTON
    It isn't easy on a 120 cdti, in fact its a pig of a job, even the stealers hate doing them. I would imagine the majority of the £133 is for labour as the part is about £40 from the stealer i believe.
    Was told it was a pain on the 120 so in the garage it went. Need a new EGR said about £70 plus fitting I could do this myself. Should I fit A fiat blanking gasket to the new EGR or just have the standed gaskets on?
    Thansk Steve
    Hope the EML goes off
    Regular Member Marky's Avatar
    Jun 2006
    North West
    The price for the Thermostat on the CDTIs isn't too bad. Its an awful job.
    £70+fitting for an EGR sounds ok also. Should only be 30mins labour max for a garage.
    You can replace the EGR yourself its easy. I put the Fiat EGR semi-blanking plate on mine and I don't see any difference. Its was only a few quid so not that fussed.
    Oct 2009
    Luton
    Therm job on 8v cdti is 2hrs labor time!
    Regular Member vecsxi's Avatar
    Nov 2005
    liverpool
    £133 bite there hand off, i did mine last year and was a nightmare as you have to remove half the egr system to get to one bolt!!!!!!
    Redditch
    Just had mine done on a 150, £112 all in but it was a warranty job so happy to let the garage do it
    Well the thermostat is done sits on 85 all day just need the EGR replaceing after my hol's
    Steve
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
