Results 1 to 10 of 16
Thread: Help - Steering wheel warning sign??
    Regular Member mishima's Avatar
    UK
    Question Help - Steering wheel warning sign??
    Hey guys,
    Yesterday I was driving down the road and a warning sign came up of a steering wheel with a "!" next to it. Again, this morning when I used the car the steering wheel warning sign came up and then went off.
    Any ideas what the problem could be? Is this something to do with powered steering?
    Cheers,
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Mishima
    first job check steering oil level,if it's low you will ruin the pump using it with low level,its electric over hydraulic so it may be a water problem from driving through water or power washing.also it may be an early telltale of alternator trouble,hopefully it's one of the first two
    UK
    Thanks for the tips mate, how do I get to the oil level res? I really hope its not been leaking oil, I noticed something on the drive a day or two ago!
    Jul 2009
    Engine : 20 Dti
    Remove right front wheel remove inner plastic protector panel and you will see the dip stick,oil needs to be on max,it's fiddle you may need a small funnel and pipe from inside engine compartment.between bulkhead and air cleaner housing.i use a squeeze bottle and plastic pipe,whatever works for you.
    UK
    Thanks, will give this a go tomorrow then
    Nov 2010
    Rugeley
    Default Steering wheel symbol
    Hi Mishima,
    If we are talking about the same warning light then it is your brake pad wear sensor.
    Give me 5-10 mins and I will post some pic's.
    Regards,
    Adam
    Nov 2010
    Rugeley
    Default Steering wheel symbol.
    I have attached three pic's
    1) Pic 1 - The "steering wheel" pic. I think this is supposed to be a caliper. - Not very obvious is it ??
    I can only comment on the front pads as I haven't changed my rear ones yet so I don't know if there is a sensor on the rear as well?
    But... On my Vectra C (1.8 LS) front nearside pads there was this wire connected to the outer pad.
    The wire is just a loop that light up your dashboard lamp when the loop is broken. The loop is broken because as the pads wear down the plastic wears through until the wire inside breaks.
    2) Pic 2 - The wire that wears out (and doesn't come with replacement EBC pads!!) £7 - 8 off Ebay.
    3) This end goes into the pad to wear out.
    Hope this helps.
    Adam
    UK
    Hey mate Thanks for the post, its not that one... I had that one some months ago, this one looks a bit like the MERC badge with the "!" next to it. Pretty similar though those symbols appreciate you tryin to help.
    I can tell that getting to this steering wheel bottle is going to be tough!! They always put things in stupid places - behind the bumper/wheel!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by jonnybravo View Post
    Vauxhall do love to make simple tasks a pain in the butt.
    UK
    Quote Originally Posted by Grumpy1954 View Post
    Exactly... I think they do this in order for the ordinary punter to get disheartened and end up taking it to the garage and thats where they make the money!
  1. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  2. Steering wheel warning light
    By ColinB in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2010, 21:20
  3. steering wheel sign on my dash....
    By PAULMAC77 in forum General Chat
    Last Post: 5th January 2010, 21:53
  4. Steering wheel warning light?
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 22:33
  5. Steering wheel sign...power steering cut out..what can it be
    By vec3.2 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:07
