Thread: Knocking from front under braking
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Default Knocking from front under braking
    Hi guys,
    I'm getting a knock under braking, but only from the front passenger side. From reading up, sounds like drop links, top mount......anything else it could be?
    Thanks!
    CDTi SRi 2006 is the car btw
    Jul 2009
    Stoke on Trent
    Anyone at all? I've read up on the arb's, drop links and top mount, doesn't sound like those but can't be 100%.
    Aug 2007
    warwick
    Hi nick_s,
    i have had the saem thing from my vectra 54 plate 150,
    under 30 mph if i change the direction of the vehicle, i.e, if i am at a constant speed and then brake, i get a knock, then if i accelarate i get the knock again, it is most obviouse if you come to a stop then start of again, i have but it into three different garages, i have had the struts that go in the middle of the springs replaced, still the same issue, i put it into vauxhall the last time, they stripped the suspension out, they said that at 111000 miles there are things worn there, but nothing to cause the noise they can hear, there is nothing damaged or dangerous, did you ever track your knock, as vauxhall said just carry on as normal, its not dangerouse but id rather have a car that does not knock.
    the only thing i can come up with is i have a tow bar, and it was on one of the first towes we did the knock come, so wondering whether the load has damaged something in the frame, and also while towing the caravan, i managed to really burn the clutch once on a bad hill, just wondering if i have damaged clutch or dmf?
    Aug 2007
    warwick
    Hi nick_s,
    Jul 2009
    Stoke on Trent
    I've not traced it yet no, but it does sound like the springs moving in their seats according to a chap on vxon. I'll be stripping down the suspension so will be doing the spring seat mod (plastic sleeve over base of spring).
    scotland
    i dont think it will be the top strut bearings as these are generally noisy whilst turning the steering at low speed, have you had a look at your front arb bushes, it also could be your suspension arms, if you can get someone to walk alongside the car when you drive at low speed and when you brake get them to check and see if the wheel is moving forward or back.
    The only way to diagnose knocking noises is to fully inspect the suspension system
    I reported a knocking noise when I first had my car, three times
    On the first visit, nothing found
    On the second visit, they spent more time, still nothing
    on the third visit, they took the car for a test drive and agreed there was a noise
    They then placed marking strips on various suspension components, but nothing was showing as contacting
    They then placed marking strips on the front bumper and panels
    They found two marking strips were contacting
    Turned out the tray under the engine was moving against the bumper, but they couldn't think of a solution "You'll probably have to live with it"
    Wedged in a large double sided sticky pad on each side, job done
    At the next service they reported the engine tray had been held in with sticky pads, and so had replaced all the screws
    Yes, you guessed it, the noise was back
    At the following service I pointed this out, and they fitted new pads
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Check that the wheel is well tightened. Check the 5 bolts.
    Jul 2009
    Stoke on Trent
    Well I have had the front springs changed today as passenger side snapped! Stress fracture, metal was solid, no rust.
    Knock still there, but my mechanic brother is stripping down the brakes tomorrow as he thinks its the caliper.
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Ive got excatly the same noise at the mo, it all most feels as if something moves when braking like a drop link, will be watching this
  1. Knocking sound when braking
    By JezzerD in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 20:44
  2. uneven front braking
    By jodiexii in forum Introduce yourself.
    Last Post: 8th February 2009, 15:58
  3. Knocking noise when braking!!
    By dave collingwood in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2008, 07:53
  4. knocking from rearwhen braking?2007 28k
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 15:39
  5. Knocking noise when braking?
    By karlp606 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 12:29
knock on my 2.2 vectra under braking
