Results 1 to 10 of 13
Thread: misfire on a 150 cdti- help pls
    Regular Member robk6112's Avatar
    Halifax
    Default misfire on a 150 cdti- help pls
    RIght ive got a 130k 150 cdti and since been stook in traffic for an hour and a half last week it now has a mis/ hesitation between 1500-1800 rpm. In the past its had an egr valve, swirl valve flaps done and the 3rd injector mod. The spanner light is on for the first 30 seconds of driving- its been like this for months and no garages can find a fault and just reset it- Any ideas-...
    Regular Member sebadee's Avatar
    macclesfield
    Try changing glow plugs my spanner used to do the same and sorted it by changing plugs
    Regular Member Mopar Man's Avatar
    herts
    Whats the fault codes read?
    macclesfield
    No idea I had some glow plugs in the cupboard so Changed them an it went
    dunfermline
    i am havin same problem but no fault codes are coming up!!
    Halifax
    right ill get some glow plugs then. Also is there a link to cleaning the boost sensor because i have never done that
    Halifax
    Can someone put me the link on to cleaning the boost sensor as ive never done this and want to elminate it- Thanks
    Regular Member M65's Avatar
    Bolton
    Halifax
    Thank you m65
    Bolton
    No worries. Only just noticed too that your car (I presume thats it in your avatar) is pretty much the same as mine.
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. CDTI 150 'misfire'
    By lesj in forum Engine & Drivetrain
    Last Post: 12th February 2010, 22:30
  3. 1.9 CDTi MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 19th March 2009, 23:28
  4. Misfire on CDTI SRI 1.9
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 21:06
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
