Thread: Quick Question - Need a Quick Answer if Possible
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Quick Question - Need a Quick Answer if Possible
    The wire on the passenger side hub that goes from the ABS / TC sensor to the wiring block - is it one wire or two stuck together?
    Think I damaged mine (either that or knackered the hub when changing front pads) and was going to try a bypass with some spare wire. Just need to know if I need to strip it all back or if I can just use a press connector.
    TIA
    Engine : 1.9 CDTi
    Pretty sure there are 2 wires
    Tain - Easter Ross
    Damn. Bit more stripping and joining then.
    Regular Member Diesel Dude's Avatar
    Norfolk
    Yep there are two wires inside the insulation one brown and one blue
  1. Quick oil question!
    By Chip in forum Engine & Drivetrain
    Last Post: 3rd December 2012, 15:52
  2. Quick oil question!
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2012, 23:38
  3. More on SCV's Quick answer please!
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 12th September 2012, 19:42
  4. caliper carrier bolts quick answer needed
    By james walker in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 17:23
  5. V V Quick answer Req.
    By Baldy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 11:57
