Thread: hid fitting
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default hid fitting
    eventually ordered my hid kit should be here this week ,(hq autolighting £50)
    6000k 35w, i know its an"easy job" but is there a guide on here or just some pointers to help me along.
    thanks as always
    Regular Member M65's Avatar
    Bolton
    Regular Member TomiboyC's Avatar
    Aug 2007
    East Ayrshire
    done mine on sunday, take out the airbox on drivers side and also the washer bottle filler neck on passenger side and this should give you enough room both sides to work. connect up before fitting to confirm everything works that way you know which way round the wiring goes etc. did this on sunday and first go i got the spade connectors round the wrong way
    stockport
    Thumbs down
    Quote Originally Posted by mrk View Post
    thanks as always
    It really is quite easy,but take care when you cut the hole in the rubber headlight cover.Make sure it's not too big and that the grommet on the HID bulb fits snuggly,and last but not least,once you've stashed the wiring block inside the headlight itself,REFIT THE RUBBER COVER BACK VERY CAREFULLY.If you don't it will come off and you will end up with moisture in your headlight!.(Then it's an afternoon with the wife's hair dryer!).FELIXX.
  1. HID Fitting Help!
    By Adam-morrison in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2010, 13:21
  2. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  3. When im fitting
    By PAULMAC77 in forum Styling
    Last Post: 3rd April 2009, 15:30
  4. fitting a PS2
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 09:30
