Thread: Gutted ... suspension
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Default Gutted ... suspension
    Well I have a broken rear spring, Vauxhall quoted me £260 to replace rear springs (both) obviously this appears on the expensive side, I spoke to kwik-fit (I know I don't trust them either) they quote £60 each corner. Thing is can I get away with just one being fitted or could this cause issues?
    Ideally I wanted a set of eibach's but money is tight GUTTED
    Ps got MOT in 3 weeks so I can't really save up enough for eibachs before then
    Jun 2006
    Near Edinburgh
    Springs shold really only ever be replaced in pairs, although if your planning to change to Eibachs shortly then just get the one side done imo.
    WGAF#5
    there is no legal requirement to replace a BOTH springs BUT if one has failed the other has no doubtly travelled a very similar route and you have to ask the question if its upto the job ..... money may be tight but a set Of Eibachs will still be cheaper than a pair of Vx springs = you can get the set of Eibachs fit the rear pair you need now and when you have a little more then fit the fronts - rears you can even do yourself
    Jul 2010
    Skipton
    Good idea mate, think I will get a set of eibachs then just get them to fit rears until after MOT. Probably be £40 to fit them plus £150 for springs.
  1. i cant believe it, gutted.
    By dansri in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2012, 16:20
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. gutted
    By scottyd in forum The 'Off Topic' room
    Last Post: 5th January 2011, 13:37
  4. gutted
    By otl1uk in forum General Chat
    Last Post: 15th August 2009, 11:00
  5. Gutted
    By BigP in forum General Chat
    Last Post: 13th August 2009, 16:57
