Thread: Towbar fitted - exhaust now banging
    Feb 2011
    London
    Default Towbar fitted - exhaust now banging
    Hi all,
    Fitted a Towequipe removable bar to the Vectra at the weekend, however when driving the car, there seems to be quite a bit of "banging" coming from the back of the car. I assume this is the exhaust hitting the bolts.
    Has anyone else had this problem and been able to overcome it? As it's the 100 edition SRI, it has twin exit exhausts, maybe making the noise doubly loud!
    I can't think of anything else it could be te be honest.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Park half on pavement or reverse on to ramps to be able to get underneath.
    With engine cold try moving the zorst around with your hand and try to recreate the noise. If its banging you should be able to find the noise.
    Leicester
    Should make any difference as the towbar is bolted on the back panel. The bolts should not go anywhere near the exhaust.
    When I fitted my tow equipe bar to my first vectra there was loads of room.
    Feb 2011
    London
    Quote Originally Posted by Maverick View Post
    The bolts are directly above the exhaust backbox on both sides.
    Aug 2010
    Derbyshire
    Quote Originally Posted by mat View Post
    I had this very problem on my Signum.
    I pinched one of the rubber hangers on the back box together with a couple of cable ties. It doesn't slop around on the hanger so much now. It's stopped it knocking on the towbar bolt when I go over rough roads, of which there are plenty around here.
    Mick
    Leicester
    I know they are directly above, but you should'nt see any problems.
    Regular Member Steve01's Avatar
    Aberdeenshire
    Where do you get these towbars I want a removable one for my motor
    Regular Member Neil71's Avatar
    Oct 2007
    Fraserburgh, Aberdeenshire
    I had the same problem with my V6 cdti, I got slightly longer exhaust hangers from my local tyre n exhaust centre and that resolved the problem.
    Towbar I had was a witter detatchable.
    After a while I fitted original VXR boxes and that cured the problem with plenty of clearance.
    Regular Member eaglepva's Avatar
    Up North
    Ive got the same problem on my signum knocking from the rear which im 99% sure is the exhaust knocking on the towbar bolts. Its a bosal detachable swan neck. Think i will try the cable tie method.
    Feb 2011
    London
    Found out this was the Offside exhaust box banging on the towbar and not the bolts. I'm going to just remove the whole thing and refit when I need it - pain in the ass but stops the banging!
  1. New towbar fitted
    By shane31 in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 10:24
  2. Replies: 18
    Last Post: 14th May 2010, 21:36
  3. new exhaust fitted at last
    By collow123 in forum Styling
    Last Post: 11th June 2009, 19:51
  4. Anyone who has fitted a towbar
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 20:11
  5. Removable towbar now fitted
    By Duncan in forum Quick Photo Album
    Last Post: 6th February 2008, 19:32
stop exhaust hitting tow bar
how to stop exhaust banging on tow bar
