Results 1 to 10 of 14
Thread: anything else to change when doing springs and shocks??
    london
    Default anything else to change when doing springs and shocks??
    I've kind of recycled a really old thread of mine......as it now......
    .........finally looks like I'm gonna get paid out for the accident in nov 07 that wrote off my then beloved n reg corsa sport
    Anyway- the upside is that it now means I'l be replacing the springs and shocks on my 03 elite so am trying to get my list of bits needed and advisable to change while its stripped down :-)
    so far i've found out i should do
    -springs and shocks
    -fit noise reducing spring sleeves- front and rear? - top and bottom??
    -upper front shock mounts
    -front drop links
    -rear upper control arms
    I've also read its worth leaving it a couple of weeks before getting the 4 wheel allignment and camber adjusted back to spec at a garage that users hunter equipment.
    so my question is- what if anything else will need doing or is best doing just in case and while the beast is stripped down??
    also not wanting to lower much so gonna go for sri spec springs by lesjofors and b4s or monroe shocks which'll give a modest 15mm drop on my elite, though I hope it'll be a bit more as she's a tall girl lol
    Any other advice greatly appreciated.
    cheers guys
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    A.R.B. Bushes/Drop Links/Strut Bearings
    I Got My 4 Wheel Alignment Done..Some Difference Likes
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Spring sleeves go on the bottoms of the front springs, also replace the strut top bearing. If your going to replace the front drop links i'd also replace the front/rear anti roll bar bushes (as they aren't expensive)
    I wouldn't bother changing the rear upper control arms unless your having problems as they are a pain to change and you don't touch them when fitting the springs anyway.
    london
    I had them done aboot 35k ago but the o/s one has a little play in it already- moves about 2mm when i do the test- the left doesnt move. could it just be loose or is it worth changing the pair as if one is gone the other cant be far behind???
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Im looking at doing this aswell, has anyone got a part number for the strut top bearings? and are there 2 different types? or just one for standard and sports setup?
    london
    good question ;-) and why are they different when we can just stick sports springs onto a standard spec vec and also the shocks are all the same anyway???
    Aug 2010
    York
    Quote Originally Posted by delberto View Post
    Dont know bud, just seen one labelled as sposrts version , i assume they are all the same. I have seen some on http://www.vauxhallworldparts.com/
    they any good or better gettin vauxhhall ones
    Aug 2010
    York
    http://www.vauxhallworldparts.com/pa...e=40&cont=true
    Strut bearing here bud, someone confirm thats the right one?
    Cheers Guys
    london
    so is it just the bearing thats changed and not the whole mount??? that'd save some wonga- the whole mount kit is 60quid :-O
    Aug 2010
    York
    yeah mount kit is about that, im sure you can just do the bearing, im not too sure tho.
    Be interested to know!
  1. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  2. Springs on std shocks
    By JSYSH466Y in forum Styling
    Last Post: 26th May 2009, 20:07
