Results 1 to 10 of 24
Thread: Safeguard
    Default Safeguard
    Hello all,
    I ahve just purchased a 56plate 1.9CDTI SRI 150. I keep getting the safeguard message coming up. I have been looking through the past receipts and it has only done 2k since August 2010.
    I have diconnected the battery for 10mins and taken out the 40amp fuse in the boot for a fe minutes but the messgae keeps coming up.
    Any help greatly received.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    This is just not a dig at you but everyone
    It's plain to see this is a technical question regarding a problem ! It takes seconds to check forum and see there's a section for this....
    Take it back to garage and get codes read, failing that it could be a sensor or power sounder in boot.
    Irmscher Insignia CDTI 130
    Sorry, thought i had put it in electrical.
    Does anyone know where F23 (Fuse is located, is it in the boot or under the bonet.
    Regards
    I have had a look at the fuse box in the boot and there is no fuse in 22, look at some of the threads sholud there be a 5amp fuse in there.
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Should tell you in your user manual if you have one
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Fuse 22 is for ultrasonic sensors check here http://www.vectra-c.com/forum/showpo...89&postcount=4
    I tried putting a fuse in and disconnecting the battery overnight, came to switch it on and the safeguard message was still on. I have visually check the connectors on the rear side windows and i can't see any breakages.
    I have got it booked into Vauxhall on Thursday but don't want to spend £60 for them to tell me it's a fuse.
    Tried the ultrasonics, ie locked the car with the remote and then opened the door with the key and the alarm went off. Tried creating the circuit with the rear windows witha paper clip, but was still getting the safeguard message.
    Took it to the local garage, the cleared out a couple of codes but were unable to go into the system as thier machine didn't have the correct chip. Felt like it was running a bit rough could that have anything to do with the garage machine or is it my imagination.
    Any help boys and girls would be greatly received. Come give a bloke a leg up.
    milton keynes
    Have you checked the under bonnet switch , its just above your air box , its a plunger type switch , my old preface this gave me the problem where the mounting had broken.
    The bonnet switch seems fine, that catch isn't broken and it moves up and down.
  1. Safeguard
    By redgers in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 16:44
  2. safeguard
    By stonie110 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th April 2010, 08:46
  3. safeguard
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2010, 17:50
  4. safeguard help
    By hmc_vectra in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 01:09
  5. Safeguard
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2005, 12:44
