Thread: Flat battery... Coincidence that I've just fitted reverse sensors?
    Chelmsford
    Default Flat battery... Coincidence that I've just fitted reverse sensors?
    Just went to start my Veccy and battery is dead! Reading 10 volts or less after a couple of turns of the starter.
    I spent a few hours today fitting and testing my new parking sensors. All seemed fine, they work like a dream, I'm well pleased. Got them connected up to the reverse light positive feed and the common neutral on the nearside light cluster.
    I'm guessing that my now dead battery is just down to me having the car open for hours with the lights on etc, but I'm worried that it could be something that I've screwed up!
    How can I test the to make sure my parking sensors aren't at fault?
    I noticed when trying to start the engine earlier that the centre display was telling me that various bulbs were gone at the back (both sides). All lights working fine though... Reckon this is just a result of the electronics going haywire because of the low voltage from the battery? Also found that the locking is playing up (which also seems to cause the radio to emit a couple of bursts of static!)
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by DNS View Post
    Id put it down to exactly this. Maybe your battery is on the way out too.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Yeah, mine does it all time if I'm messing with for few hours.
    Regular Member RLFH470's Avatar
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    Same thing happened to me when I fitted my front and rear Dolphin system. Finished the work on a Friday, didn't need to use the car until the Sunday, went to start it and just got a clicking solenoid sound. I then relocated the Dolphin system power feed to a switched feed and haven't had a problem since.
    Regular Member Innes's Avatar
    Plymouth
    Same thing happend to me after having the door and boot open for a couple of hours and switching on and off the iginition without turning the engine over. My battery was close to the end of its life anyway it this was the straw that broke the camels back!
    Chelmsford
    My battery is a genuine GM with a little window in the top to supposedly show how good it is...
    I can't see anything through it! Is this normal for a duff battery? I don't remember it showing green even when it was brand new
    Oct 2007
    Shropshire
    It is obviously green when you look thorugh it normally...
  1. New battery fitted and its still going flat ??
    By m8wos in forum Engine & Drivetrain
    Last Post: 1st October 2011, 20:29
  2. Reverse sensors
    By silverhairedracer in forum Insignia car chat
    Last Post: 27th October 2009, 22:44
  3. got me reverse sensors fitted at last
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 14:55
  4. Reverse sensors
    By badge25 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2007, 23:10
  5. reverse sensors
    By signumT in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2005, 18:41
