Results 1 to 10 of 11
Thread: Service light question
    London
    Default Service light question
    If this is an old answered question I apologise but my searches have resulted in dead ends.
    I hold down my trip reset button and after a few seconds I see the oil car and spanner icon show up with 10.000 bellow it.
    my question is what exactly does that represent an what does the 10.000 figure tell me?
    thanks for your replies
    This is known as ECO Flex servicing
    The car monitors the oil and component conditions and adjusts the service interval, if required
    Tends to be quite accurate too, if 5W30 GM-LL oil is used
    10,000 miles to next service
    Counts down in units of 1,000 miles
    At 1000 miles the count down ends and an oil can and spanner appears when you switch the car off
    At 500 miles the oil can and spanner appear when you switch the ignition on
    At 0 miles the oil can and spanner stay on
    On service the counter is reset
    This varies between 10,000 20,000 and 31,000 depending on engine
    On mine it is 31,000 which is ridiculously high for a diesel
    However, in the final 5000 it drops like a stone...
    Woodbridge
    I beleive it is meant to be 10,000 till your next service. If it needed to be done then that light would show at start up.
    For some reason mine says 30,000, its going into VX this week for a service, they can sort it then.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    It just depends which service interval was programmed into the car when it was new. The number varies depending on which type of service plan it was put on.
    London
    thanks for reply.
    I thought that was it too but if it was miles until next service then it should be counting down but its had 10.000 since i noticed it a month ago.
    Its showing you the amount of miles still to be covered before the next service is due if long life oil is being used (Its set on ECOservice and long life oil should be used if you want to keep it at 20000 mile service intervals.)
    EDIT: Too late.
    London
    ok so that 10.000 tells me i should service car every 10000 miles? and if last service was 63000 i should see an indication around 73000?
    London
    im having it fully serviced saturday as i cant verify the authenticity of the fully stamped service book.
    Quote Originally Posted by ryantcb View Post
    No its counting down in units of 1000 miles.
    You will see what the service interval is when the instrument is reset as
    it will revert back to the high figure. Ask the garage that carries out the service to reset it.
    Or try this to reset it yourself- Ignition off, hold in the trip reset button and press the brake pedal down, keep both pressed and switch on the ignition.
  1. Service light question
    By GerryB74 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2011, 14:57
  2. Quick service light question
    By Keithy in forum General Chat
    Last Post: 27th December 2009, 23:18
  3. Question about that Service light/icon?
    By Rainbow6six in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2009, 14:14
  4. Service light/mileage question
    By matth42 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2008, 22:11
  5. Another service light question...
    By FiscusFish in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2007, 13:40
