Results 1 to 10 of 16
Thread: CDTI 150 standard boost pressure?
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default CDTI 150 standard boost pressure?
    Does anyone know this?
    Engine : 1.9 CDTi
    18 PSi I think
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Cheers Lee. I'm having a few issues with my car. It's remapped and hits 22psi, wasn't sure what the standard pressure is. At least now i know it's running higher than standard.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    95 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    The opcom readout on mine shows 1.35 bar (approx 19psi) above atmospheric pressure when accellerating at full throttle. Not sure how accurate that is though!
    Regular Member dog 389's Avatar
    Feb 2011
    northampton
    i was thinking off fitting a boost gauge to the interior, does anyone know if this mod has been done?
    Regular Member Mopar Man's Avatar
    herts
    Without remap, my boost will go to nearly 30psi.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Hmmm. Lots of different pressures there.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Standard boost is 1,4 bar / 20,3 psi.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    is 20psi for all 1.9's???
    Sep 2010
    in a box
    so what is the psi for a 1.9cdti??? as id like a boost gauge but most only go to 20psi
  1. Boost pressure - CDTi 120
    By zafira in forum Diesel Engine related
    Last Post: 23rd October 2010, 20:10
  2. Boost pressure CDTI 150 what should it be?
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 18:06
  3. Boost pressure
    By Mark2.2 in forum Petrol Engine related
    Last Post: 23rd January 2010, 18:46
  4. Boost pressure on 1.9 cdti 150
    By andreitone in forum Engine & Drivetrain
    Last Post: 9th June 2009, 20:48
vectra cdti boost pressure
1.9 cdti 120 turbo boost pressure
z19dth boost pressure
1.9 cdti boost pressure
standard boost pressure on a vectra cdti 150
vectra c cdti 150 turbo
1.9 cdti 150 boost pressure
vauxhall astra 1.9 cdti 150 standard psi
standard astra 2.0 cdti boost pressure
vauxhall vectra sri turbo boost gauge
1.9 cdti turbo boost
how much boost can a standard vauxhall vectra turbo take
astra h cdti boost gauge wiring
turbo pressure opel astra h 1.9cdti
22psi boost astra cdti
opel astra 1.9 150 turbo pressure
Astra 1.9 cdti normal boost
2007 opel astra cdti maximum boost
increasing z19dth boost
astra 1.9 cdti sri 150 boost problem
z19dth constant boost
astra h 1.9 low boost psi
Vectra c Sri cdti standard boost pressure
vectra c 1.9 cdti boost pressure standard
vectra 1.9 boost psi
