Thread: My Radio Will Not Turn Off CD30
    HULL
    Default My Radio Will Not Turn Off CD30
    I have had to disconnect my radio CD30 as it will not auto turn off when i turn engine off ,take keys out etc,
    Could something be shorting somewhere ?
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Two items..
    1) Have you turned off ignition logic in the settings... ?
    If yes, then you need to turn the ignition logic back on.
    2) If the ignition logic is still on, then there is a common fault on some CD30's, which turn themselves on, or refuse to turn off, resulting in a flat battery..
    Not sure if it is the radio or display... think it is the radio.
    Only fix is to get a replacement radio !! - Sorry !
    Fortunately there are loads on Flea-bay..
    For info - the wiring to the CD30's is the same across the whole Vauxhall range... BUT and this is a big BUT
    The screens for the Vectra-C and Signum are the only screens wired up correctly...Corsa c / D or Astra H screens will not work in a Vectra-C
    So do not get a matched pair from e-bay, you need a divorced radio. Unless from a Vectra-C
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Hang on this there not a setting on the cd30 to have it auto-turn off? Maybe that just needs re-setting?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by ONEMINUTESILENCE View Post
    Yep see my comment 1
    (Settings - Ignition logic on / off)
  1. Turn off auto radio?
    By Rab in forum Vectra C / Signum Troubleshooting
    Last Post: 26th January 2014, 19:27
  2. Upgraded Radio won't turn off automatically?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2010, 19:40
  3. radio cd30
    By wobblywayne in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 00:35
  4. CD30 Radio
    By SRIJammers in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2009, 02:25
  5. Radio won't turn on without display?
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2007, 21:36
vectra c radio wont turn off
vauxhall cd30 radio not working
vauxhall astra radio wont turn off
vauxhall insignia radio wont turn off
my vectra sat nav does not go off when i take the keys out
sat nav c70 wont turn off with key vectra
radio not turning off in opel vectra
vauxhall vectra radio wont turn on
vauxhall corsa radio not turning off
insignia sat nav screen wont switch off
vauxhall zafira 2008 diesel automatic radio on after turning off the ignition
cd30 radio wont turn off
vectra c head unit wont turn on with ignition
opel vectra do not turn off audio
stereo zafira tourer wont turn off
vauxhall corsa 2007 cd30 will not switch off with key
vauxhall astra radio not turning off with ignition
07 vauxhall astra radio unit wont turn off
cd30 not turning off
astra h cant turn radio on
cd30 radio not responding
vauxhall zafira radio not switch off when key out
my car radio wont turn off insignia
signum radio doesnt work with inshion
vauxhall meriva why doesnt radio go off after turning engine off
