Thread: Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    HULL
    Default Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    Hi , My brake warning light is on and also the BRAKE LIGHT warning message on the display , But all 3 brake lights are working Fine .
    Any ideas ??
    Vectra C SRI 2008
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    have a second look at them check to see if they are level , these cars use a side light as a brake light if a brake bulb fails
    Full Member Big Sig's Avatar
    I bet ones blown and you haven't looked close enough
    taunton
    yep they are right it happened to me.
    Equally, one of them can be at the end of their life
    Swapping with a new bulb and process of deduction will determine which it is
    Normally the upper one
    New Member lexus_dave's Avatar
    Sep 2010
    sunderland
    mine was down to a couple of leds gone in the third brake light
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by JACKALG1 View Post
    Any ideas ??
    Vectra C SRI 2008
    It might not be brake light malfunction, which warning light??? is it for brake fluid level low, or low brake pad warning indicator, similar warning lights....
    Jan 2013
    north wales
    ill have to check mine ive just had the same problem where i press the brake and te brake lights arent level
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Just had same problem, both workin!! i changed both bulbs just to be sure but it keeps poppin up on GID & dash! Im gonne take light out ox and clean the contacts to see if that helps. Any other ideas? Tia
    May 2013
    Wakefield
    Vehicle : Vectra c estate
    Engine : Z30cdti
    Year : 07
    Mileage : 97,000
    I know it's going back a bit , but did you solve the problem with the brake light bulbs pal, it's just started on my vectra estate .. Be grateful for any ideas pal .
  1. Brake light warning message on display
    By don1966 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2011, 11:15
  2. Brake light warning message
    By babilon2 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 16:03
  3. "BRAKE LIGHT" Message in display...
    By Westy SRI in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 23:35
  4. brake lights stopped working
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2008, 21:57
  5. brake lights stopped working
    By peadar in forum Handling & Braking
    Last Post: 6th October 2008, 07:22
vectra c errors brakes
vauxhall vectra brake light warning light on but brake lights work
vectra c 1.9 cdti brake warning light
