Results 1 to 10 of 22
Thread: Disappointed with my headlights.
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Default Disappointed with my headlights.
    Like the title I don't like the way they shine, it's like it was worse than before. I have ordinary, non-xenon facelift headlamps. Maybe it's just a feeling but when I compare it with some other cars it doesnt make me think optimistic aswell. For a long time I've been thinking of fitting xenons. AFL's would be the best but as I presume there will be many problems with fixing them. My father has AFLs in his Passat and I'm delighted how they shine.
    So, I need your advices:
    -what can I do to improve visibility (better bulbs, HID's, xenons)
    -if I wanted to fit AFL's what requirements should I meet?
    -cost of each mod?
    Thanks in advance
    Jan 2011
    lincolnshire
    they are rubbish on the vec C as standard , upgrade is the way forward
    lanark
    6 Post(s)
    Year : 2017
    http://www.hids-direct.co.uk/hid-con...its-p-445.html
    vectra lights are not good get a set of these in
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I went with Duncan's mod to raise the level - set appallingly low on dip beam, then fitted uprated Xenon bulbs. May try Osram Nightbreakers next, but raising the level made a big difference.
    Jan 2011
    Glasgow
    I find my standard headlights are 100% than my previous car!
    G
    Oct 2010
    Poland
    Thanks for help!
    I like the HIDs idea, do I need to fit headlamp washers if I get them?
    Regarding Nightbreakers bulbs I heard that their liveness is shorter is it true?
    AFL's conversion, anybody?
    Regular Member Ginge7289's Avatar
    Jan 2011
    Woodbridge
    Put some HiD's in as said above. Easy to do, easy to remove if you change the car. The extra light is amazing, only fitted mine yesterday.
    There are some pics in there with mine, the first pic is the Mtec sides, second is obviously both.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by Grumpy1954 View Post
    Agree with Grumpy....
    I've just done Duncan's mod for the dipped beam lamps on our 55 reg Facelift Club spec Vectra, which has the standard 12v 55watt Halogens fitted ....but only at position 1... and I thought it made a significant difference to spread & distance.
    Duncan's was at position 2 & must be even better....
    AND - today - I've just changed the Dip beam Halogens for Ring Automotive 12v 55watt Xenonmax..with even more improvement & referred to in the thread below....
    The light is 'Whiter' significantly more so than the standard Halogens on Main Beam which I intend to keep as Main beam lights up the road ahead enough for me...
    I've just been out to try 'em and am well satisfied so far...
    See this Thread for more opinions...
    http://www.vectra-c.com/forum/showthread.php?t=97177
    I now might go the whole way on Duncan's mod at position 2.....
    Cheers
    Oct 2010
    Poland
    Sounds interesting, thanks Tony
    Mar 2010
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
  1. Bit disappointed really.
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2013, 21:12
  2. I am very disappointed in Vauxhalls.
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 09:21
  3. Disappointed
    By Wilco in forum Detailing and Car Care Discussion
    Last Post: 15th June 2009, 17:37
  4. I'm Very Disappointed
    By VauxVeteran in forum 2008
    Last Post: 30th April 2008, 16:36
  5. Very disappointed...
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 30th October 2007, 23:58
