Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Boost Gauge in Centre Vent
    Regular Member Keif's Avatar
    In the Garage
    Default Boost Gauge in Centre Vent
    My next thought for a project on my Signum is a boost gauge.
    I don't want a pod on the dash so was thinking about fitting it into the driverside Centre air vent.
    Has anyone done this? If so pics?
    Or is there a version like this from a Vectra/Signum?
    I realise that the idea will have to be different dur to the slats being separate.
    Searched on here and really like the gauge that Duncan fitted (with the snazzy start up/shut down sequence). I believe it was a version similar to a Delfi gauge (which they don't make any more)
    Duncans Video. (Start Up)
    So, where do I get one from? other than searching for "Boost Gauge"
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    i looked into it and decided i did not want to loose the vent... i mounted it on a pillar pod instead as i also did not want it in the dash pod.. somebody mounted a gauge in the single vent above the lights switch but it looked a little too Blue Peter for my liking, i can't find the thread to show though..
    In the Garage
    Can't go Pillar Pod, due to an AirBag.
    Off to search for the "Blue Peter" effort.
    Oct 2007
    Shropshire
    If you find it let me know!
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    which airbag?
    In the Garage
    Quote Originally Posted by Caveman_nige View Post
    which airbag?
    In the A-pillar.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Where did you get that vent from! i've been lookin for one of them
    In the Garage
    Spoons, can't fault you for posting the link to your thread. Really neatly fitted, but as posted in the original post. Cant (and don't want to) go for a pillar mounted gauge.
    Super T, you need to re-read my original post. I'm looking to fit a gauge in the vent (that ones from an Audi)
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    if you put pillar pods halfway up the pillar then you will have an issue, but if you put the pod low down near where you would put a naff dash mount pod then you will not have an issue..
    If you remove the A pillar trim you will see that having a gauge down on the dash area is of no consequence..
    If you look at the pics you will see i have mounted a 60mm gauge forward and below the airbag to be any problem.. furthermore it is mounted by sticky back velcro and if the airbag deployed it would go onto the dash by the windscreen..
  1. For Sale: 2 Gauge Vent Surround Conversion
    By Knight Rider in forum Parts for sale
    Last Post: 22nd November 2012, 22:47
  2. Centre Vent Gauges
    By Knight Rider in forum Styling
    Last Post: 15th November 2011, 22:20
z30dt turbo gauge
vauxhall vectra air vent gauge
vectra c boost gauge vent
vectra c boost gauge fitted
