Results 1 to 10 of 15
Thread: What are the best tyres to buy????
    Regular Member John3v36's Avatar
    NI
    Default What are the best tyres to buy????
    Hi all.
    Just asking you all - What is the best budget tyre to buy?
    I will very shortly need a full set of tyres for my 17" facelift sri wheels (unsure of technical name for them!) and am wanting to know what would the best tyre be to buy and what the prices are out there?
    thanks in advance
    Mileage : 000
    I have Toyo Proxy,s on mine I think they are very good.
    Regular Member Marcosuk's Avatar
    Fife
    I went from 215/50/17 to 225/45/17 all round when i replaced mine mate.. I used camskills website which i found to be quite good for prices..
    I was always told, try to buy the dearest you can afford
    As above, buy the best you can afford
    If unsure, then visit a local tyre specialist and ask for a listing including full specification
    Look for the highest treadwear / traction / temperature rating
    When the tyres wear out on the front, swap the rears to the front
    That way you will have the highest average tread depth at all times
    The disadvantage is the fronts will always have less than 6mm of tread, and then need replacing at about 3mm
    The advantage is then you only need to replace two at a time
    Personal preference is the Michelin
    However they ain't cheap in these sizes, so I am sticking with the Good Year that the Vectra C came with
    Sadly these were NCT5
    The GSD3 were excellent, but now discontinued
    The Assymetric is acceptable, but is due to also be discontinued in a few months time
    Avoid the Dunlop
    Acceptable in smaller sizes (up to 15"), useless in ultra low profile in larger sizes
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by ed taylor View Post
    Toyo`s Are Great Tyres
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I used to do the above and run on 2 new tyres at a time. Now I swap fronts to rears every couple of months (not alternate sizes as I have my 4 wheel alignment done also).
    I did this for the full life of my last tyres and with a heavy foot and a few races from the lights... autobahn speeds etc (90 minimum on most trips) I still covered 15-17k on a set! Thats with 2mm left on the old ones as 1.6 is far too low.
    It works out more expensive but I believe that tyres should be replaced as a full set. If you have less tread on an axle set whether it be front or back your still not getting the full performance out of your tyres on that side of the vehicle! Even wear is always going to be better than half and half. Although economically it makes sense and its still not going to cause any major problems.
    Tyres recommendations... I have 19's but found the Falken 452's too be brilliant (last set) but ordered some Vredestein Sessanta tyres as replacements after talking my friend into fitting them to his Mitsibushi Evo 8 - Heavy use, track use and great ratings in the wet have made me take the plunge... although be warned... They are rated as utterly useless in the snow! He even span out with his 4wd!.... but I have winter tyres also so its fine
    preston
    i once tried budget but no more
    have tried goodyear eagles ... ok but don't last
    michelin primacy .. last but pricey
    all these were 215/50
    now on continental contact sport...very good, i'd say better than either of above. £111 per tyre so not too expensive compared to primacy.
    just got to see how long they last
    Uniroyal Rainsport 2's. Best tyres I've ever had.
    Nuff said.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i`m using falken zeix 912`s i have covered 13000 miles the rears have around 4.5mm on and the fronts are just about to be replaced tomorrow as they are down to 2.5mm . have a look on camskills website they work out at £62 per corner for 215 50 17
    Regular Member Wolflinn's Avatar
    Camberley
    Uniroyal Rainsport 2's , high quality tyre a mid range price.
  3. More tyres....!
