Results 1 to 10 of 22
Thread: Vectra V6 CDti Injector problem possibly?
    Jan 2011
    Stoke on Trent
    Default Vectra V6 CDti Injector problem possibly?
    Hi,
    this is now my 2nd post!
    Having bought a vectra 3 days ago, i've noticed that the car shakes on idle, and up to about 1500 rpm, whether in gear or not.
    It also makes a slight knock on idle, which i suspect is an injector!
    Its a 54' plate with 55k on the clock. Serviced every 10k.
    Is this a common problem? How much are injectors for this beast?
    are they difficult to change/or need coding?
    Cheers for the help so far!!
    Cumbernauld, Scotland
    Quote Originally Posted by smitd004 View Post
    Not really, not many reports
    However, yes most likely an injector has failed
    Not cheap, get parts prices from at least two VX dealerships
    Equally, if you plan to have these fitted by them get at least two quotes
    Normal recommendation is to replace all six injectors as a set
    For fitting by a local diesel mechanic make sure they have experience of the Y30DT (if unsure, turn up and ask them to diagnose)
    Five of them are relatively easy (once you get to them)
    One of them is not easy (chances are this is the one that has failed)
    Yes, on completion the EMS has to be reloaded with new voltages
    Regular Member Celes's Avatar
    Sep 2007
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    1 injector will cost you about 600 pounds or more from a main dealer.
    If it sounds anything like this on idle it will be an injector problem. I replaced all 6 and it was like new again
    http://www.youtube.com/watch?v=NRvzAcaK6pA
    Injectors do not need coding on the V6CDTi, only 1.9's need that.
    They are fairly easy to replace and any mechanic with at least a bit of experience will be able to do the job. Good luck I'm having mine done soon.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Engine : Z19DTH
    Mileage : 166000
    not sure if it may be the problem but there was something that ive known been done a couple times at my place, you dont have to program the injectors but they can be sorta synchronized which from what ive been told really helps them and makes them run as smooth as silk might be worth talking to your local dealers about
    Quote Originally Posted by vxpenfold View Post
    Yes, details are on TIS for full bank injector replacement
    Reread voltages and enter them as new values
    This only applies when you replace all three injectors on each bank or all six
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Engine : Z19DTH
    Mileage : 166000
    ah ok fair enough, i just remember being told something about it at work when asking questions about the v6 diesels
    Sep 2007
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by m8internet View Post
    Can you make a print screen of this page on TIS? I asked the Opel garage I usually use and he said they don't need to be coded...
    The do NOT need to be coded
    It is optional to reset the voltage readings
    Full instructions are on TIS
    I do not have a copy, I read this at my local VX dealership (was discussing a separate issue)
    Sep 2007
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    What difference would it make if I "coded" the new injectors?
    Quote Originally Posted by Celes View Post
    If the voltage changes, with wear and tear, then the EMS would need updating
    Coding sets a single voltage that applies to all the injectors
    This may present issues if only one injector is replaced
  1. 2005 Vectra 1.9 CDTi 150 injector seal
    By MXB74 in forum Engine & Drivetrain
    Last Post: 11th March 2012, 18:38
  2. vectra cdti injector problem...
    By betrayed in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 02:11
  3. Cdti injector problem
    By aidy-cdti in forum Engine & Drivetrain
    Last Post: 27th June 2011, 20:19
vauxhall vectra v6 cdti injector seals
opel 3.0 cdti injektor proplems
injectors 3.0 cdti change
vectra cdti injector coding
