Thread: remote locking
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default remote locking
    Hi just asking if anyone else has had a problem the same i had?
    Went out to car pressed button on remote and car didnt unlock, tryd it few times and nothing. Went in home to get spare key which is new and it unlocked, so tryd locking it again with original key again and nothing.
    So used new key and it locked. so just out of interest i swopped batterys over, that was a mistake cause after that none of the keys worked. So i unlocked car with the key in the door the alarm went off so put key in the ignition and started engine, alarm then stopped sounding and after went to lock car with remote and it worked, so i did this with the other key and a presto that worked to.
    Used the car and all seems ok now. ive not had the battery disconnected under bonnet at all. WHAT COULD HAVE HAPPENED?? any ideas anyone
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    it's possible that your old key just needs to be re synced to the car i'm sure there is a how to
    Jul 2009
    The Rift, Cardiff
    Its possible for the key to unpair if the button is repeatedly pressed when out of range. I had it went my daughter and nephew got hold of my keys.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    the battery is low on your first key which is why it needed to be re synthesized
    Regular Member V5LED's Avatar
    St helens
    Put key in the ignition turn it but don't start the car, press lock on the fob then unlock, your key should then be re-synced
    Had to do it to mine when I repaired the switch.
    11 Post(s)
    Quote Originally Posted by V5LED View Post
    Yes, that's one way to resync.
    There is another way for newer Vectra's as well - which is documented in the handbook (you know the one that no one bothers to read.)
    Sep 2009
    Glasgow
    on facelift just unlock car with key, open door alarm wil sound, put key in ignition and turn to first mark and key will be synced
  1. remote central locking
    By mifandmif in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 23:57
  2. help remote locking
    By swvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:45
  3. Remote locking (again?)
    By quba in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2006, 22:52
  4. Remote locking
    By IamtheStig in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2006, 21:21
  5. Remote Locking
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2005, 17:13
