Results 1 to 10 of 11
Thread: Both nearside inner tyres worn VEC C Turbo
    in a house
    Default Both nearside inner tyres worn VEC C Turbo
    Well, took rear wheels off yesterday to do brake pads and noticed first 1" of tread on nearside rear has nearly gone although complete rest of tyre is around 4mm across the top.
    The offside tyre has even wear all across the tyre and all tyres were same depth when fitted.
    So after the wheels were back on i checked the fronts and the same thing appears to be happening to those, nearside front worn inside about an inch but offside fairly even wear.
    New tyres going on real soon but what could be causing it???
    The car an 08 plate and not lowered (YET) but it is worrying if thats the wear ou get on standard set up
    Planning on having wheel alignment done but could there be something else wrong too.
    Regular Member Marcosuk's Avatar
    Fife
    I had this on my vec with the rears also... I replaced the front wishbones drop link & arb bushes then done the banana arms on the rear.
    Took it down to my local 4 wheel geometry alignment place which sorted everything out..
    So far , so good
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    i would say you defo need a 4 wheel alignment doing... that car is not that old to have worn out so many parts.. Has it been pot holed or had a good kerbing session...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    in a house
    no nige, it seemed to have a good life before us (as far as i can tell) and to be fair the wife is a very good driver. The cars been faultless since we had it last year and other than this tyre issue i am over the moon with it.
    Will be going down the 4 wheel alignment route very soon
    Cheers.
    lincolnshire
    def get ALL the bushes checked aswell
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    i would have asked if its driven enthusiastically but as you said your wife drives it im not so sure, a decent 4 wheel laser alignment by people who know what they are doing is vital
    in a house
    To be fair she doesnt hang about , safe and in moderation, me i love to drive it, again when allowed it just makes my vixer feel even more powerful when i jump back in that,
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    well that is a possible reason, probably not the full cause though it could be a collection of hardish driving at times and bushes that are starting to wear. ure best bet is to have someone with a proper top end 4 wheel laser aligner have a look at it and check all the bushes and joints etc over for any slight play. vectras are known to be hard on rear tires, a mates brother has a vectra on 19 inch snowies that would go through rear tires like they were going out of fashion its better now he ahs lowered it but still not great
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Some good reading here........
    http://www.vectra-c.com/forum/showthread.php?t=54068
    Seems like some tyres are more prone than others, but rear camber is difinitely an issue and needs to be set on top limit to minimise or reduce this issue. Having assymetric tyre helps as you can rotate to minimise the issue. When I had the original Bridgestones which were directional, The damage was done on the rears so once put on the fronts the tyre was worn and the noise was evident. No such problem with 19 inch contis and correctly adjusted camber.
    Jun 2009
    South Coast
    remember this is just one side of the car lads, front and back.. not both sides.. You can end up changing so many bits that do not need changing when its just needs the camber, caster and toe adjusting, fingers crossed.
  1. part worn tyres
    By luke.oldham in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2013, 10:48
  2. For Sale: x3 part worn 235/35/19 tyres
    By Kev_A in forum Parts for sale
    Last Post: 19th July 2011, 21:19
  3. Rear Tyres worn
    By tangoman in forum Handling & Braking
    Last Post: 15th June 2011, 12:24
  4. Selling part worn tyres?
    By Gregg in forum General Chat
    Last Post: 9th February 2010, 20:28
  5. worn tyres
    By dazy75 in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2010, 09:19
