Thread: Front disk help
    Apr 2009
    Fife
    Default Front disk help
    I need to renew my front brakes, i managed to get the pads out fine and the caliper carrier bracket type thing out ok, but some muppet has rounded the small hex screw on that holds the disk on, anyone know of any quick fix? or am i going to have to drill it out?
    Many thanks.
    p.s. its a 2006 1.8 sri nav if it makes a difference.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Impact Driver No Good ?
    Apr 2009
    Fife
    unfortunately not, its pretty much smooth and not hex like at all
    Aug 2010
    Dundee-Motherwell
    Chip Away At Corner N Try Hammer/Chisel/Screwdriver
    exeter
    if that does not work its drill it out and retap it . or you could try and wled a bar on it and try mole grips on it ?.
    Devon
    I had this problem. I drilled into the screw and then hammered a flat head screwdriver (one slightly bigger than the hole I drilled) in as far as I could. I was then able to unscrew it but I guess it depends on how tight it was screwed in originally! HTH
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Once the head of the bolt is drilled off the disc should come off. Then it should be just hand tight unless its rusted up. if so then file two flats on either side of the bolt thats sticking out and use a shifter to unscrew it. no need to drill and tap unless its stuck solid.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Or just hammer a larger torx drive in. Get some wd40 on it, get the caliper hot, (hard stopping) and than as fast as you can get to work.
  1. vec c disk
    By vectra2002 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2009, 11:38
  2. Signum 3.2 V6 front disk sizes
    By martinbruce in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2009, 08:43
  3. 2008/2009 Sat Nav Disk worse than old disk
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 12:53
  4. update disk/2007/08satnav disk
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2008, 19:44
