Results 1 to 10 of 11
Thread: Judder in 1st
    Apr 2009
    Fife
    Exclamation Judder in 1st
    Hello all, i''ve got a problem with my 2006 1.8 sri. When pulling off in 1st, usually the first one of the day when its cold. It seems to have a violent judder, then its fine the rest of the day.
    Has this happenned to anyone before? I would like it fixed, now im handy with the spanners but there doesnt appear to be any obvious adjustment of gears/clutch. And the car is on 69000mls so way out of its warranty.
    Can anyone help?
    Thanks.
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Sure its a known problem, your will be the VVT same as mine I think , mention of a field remedy on here but I have no idea what it is. I have this sometimes just stops after its first wobbly an doesnt happen for ages
    Chelmsford
    Got the same problem here, it's always been like it.
    Regular Member adamtaylor's Avatar
    Witney (OXfordshire)
    I have the same problem with mine (same engine!) have had it looked at by stealers but nothing found! CLutch judder on this engine is a common fault though! Mine seems to be missing a lot too but I think that may be coil pack.
    kilmarnock
    ive got the same judder, changed the clutch and its great for about a month then it comes back.
    im going to try clutch & flywheel next, if that doesnt fix it ill be trading it in...
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I had this on my 2.8 after it was sat over the weekend (around -7 at night) and then I drove to work. Our engines whack up to 1300rpm on startup for around 30 seconds before setting back on normal idle speed.
    I decided as I was late I would only leave it around half that time and set off. Got a judder/misfire feeling when putting my foot down any more than 'slight acceleration'. After 60 seconds it was fine. Just put it down to the engine being cold possibly affecting the spark... havent checked my battery connections but this can also cause a similiar problem with a poor connection.
    When you last have your plugs replaced? Mine are brand spankers so it shouldnt be them but it is possible they are on their way out
    Apr 2009
    Fife
    well it had a major service last august, timing belt got done too. So im presuming they were changed then. Might pull them out and have a look at their condition.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    my 1.8 used to do this, just once like trying to stall, only first thing in morning. Then it got worse and was missing all the time. I changed the plugs and coil pack and it doesn't do it at all. I wonder if it is the first sign of coil pack starting to go?
    Regular Member Exclusive BV's Avatar
    West Midlands
    Mine has started to do this and I was thinking coil pack too.
    Noticed the odd judder here and there when putting the power off and on
    shame they are so damn expensive otherwise i'd try one
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Thumbs up
    Quote Originally Posted by Exclusive BV View Post
    mine was doing the same.. odd miss here and there then one day it started doing it more so i floored it to clear it, this finally killed the coil pack and brought EML on put code reader on said number 4 cyl.. popped down to autovaux £64 & 5 mins to fit job done..pity your not closer you could have tryed mine
  1. Judder and eml
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 07:41
  2. Judder at 50 to 60
    By Faz2726 in forum Troubleshooting
    Last Post: 17th January 2012, 00:00
  3. judder
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 28th December 2011, 14:41
  4. judder
    By twaiter in forum Engine & Drivetrain
    Last Post: 14th July 2009, 21:26
  5. Judder at 2000rpm?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th January 2009, 13:49
