Thread: Reddot or mpg
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Reddot or mpg
    Hi
    Im looking to get a remap next month and not sure who to use...
    Midpointgarage quoted me £660 for egr valve to be removed and blanked,boost valve cleaned a k&n air filter with remap and rolling road.
    Reddot quoted £300 for a remap not sure if they can blank off the egr valve?
    Can anyone give advice or feed back on either? Also would a decat give slightly more power with the remap?
    Regular Member Mopar Man's Avatar
    herts
    Going into RED-DOT tomorrow.
    I asked for the EGR to be disabled as i have blocked it off.
    A decat will help it breath more. Remove both. Possible increase in MPG.
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    Ive had a quote of £360 at Mas Performance for EGR disabling and the DPF removed with pipe fitted plus the remap of coarse:
    http://www.vectra-c.com/forum/showthread.php?t=128897
    Aug 2010
    Quote Originally Posted by Mopar Man View Post
    What did you use to blank off your egr valve? also how do i remove the DPF?
    Oct 2010
    bradford
    Quote Originally Posted by johnnyboy1985 View Post
    Put a plate in between the exhaust inlet and the EGR. This is the DIY method.
    When you have the remap, they disable the EGR so it remains shut.
    DPF removal is being done by the remapper:
    http://www.masperformance.co.uk/dpf-removal/
    herts
    Just an oval plate with no hole in it for the EGR made out of an old biscuit tin.
    I replaced my cat with a straight through pipe and the front cat you just undo the down pipe and smash the honey cone out of DPF
    There are numerous threads on the site about these jobs and more
    Aug 2010
    Where did you get your decat pipe? will you be getting the DPF removed from the ecu when you have your remap?
    Oct 2010
    bradford
    Mas Performance make the pipe while your there after removing the Filter. then change the cars map
