Thread: Cruise Control Fault.
    Regular Member pattz123's Avatar
    Motherwell
    17 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    Default Cruise Control Fault.
    My facelift 150 cdti Vectra's cruise control drives my crazy, the fault am having is that when its on every time i indicate left it cuts off, as you can imagine its very annoying when changing lanes on the motorway. I was convinced it was the contacts on the stalk switch but after fitting new stalk the fault is still there so im guessing its the control unit that stalk connects to. Does anyone know the cost of this unit and does it require programming or is it plug 'n' play? Thanks Pattz123.
    11 Post(s)
    You're not pressing the cancel button on the stalk are you? Easy to do - have done it a few times myself when indicating.
    Jan 2010
    Sheffield
    I have a similar issue, although I can go sometimes and it will only do it now and again..
    If it is the bit it connects to then it's about £300 and called the CIM. It's not plug and play, it will require coding to the car.
    Motherwell
    17 Post(s)
    Trim : SRI
    Mileage : 83k
    Oh dear, Guess i'll just have to live with it then.
  1. cruise control fault, new stalk fix problem?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2013, 11:16
  2. vectra c cruise control fault
    By hopkinson06 in forum General Chat
    Last Post: 31st January 2009, 14:42
  3. cruise control fault
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 5th December 2008, 09:11
  4. Cruise control fault?
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th May 2008, 11:00
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
