Thread: Is IDS TC and ABS?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Is IDS TC and ABS?
    As title. Damaged the front hub wiring and have lost ABS and TC. Looking on ebay and found http://cgi.ebay.co.uk/FRONT-WHEEL-BE...item4cf3995462 - suitable replacement?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No mate IDS was an option on the vec (adjustable suspension etc.)
    You need the non-IDS one
    http://cgi.ebay.co.uk/Vauxhall-Vectr...#ht_1050wt_698
    Tain - Easter Ross
    Splendid.
    Just another quickie while you are here, I changed front pads today and thought I had broken the caliper..... what a crap design! (Can you guess what I did??!!)
    Tain - Easter Ross
    And are bothe front hubs the same?!
    Regular Member sulten's Avatar
    Øvre Årdal, Norway
    9 Post(s)
    The item linked is not for IDS. But if you have a MY 2005- you will need part number 93186388, and left and right is the same. From 2005 it's not difference IDS or not.
    http://cgi.ebay.co.uk/FRONT-WHEEL-BE...item564196477d
    Tain - Easter Ross
    Conflicting answers there. Car is a full canbus preface registered in March 2005
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by sulten View Post
    This should be the one the prefacelift half canbus ones are different, if you are in any doubt call the stealers in the morning give them your reg they should give you the part number you need.
