Results 1 to 10 of 26
Thread: fuse/ electrical Q,,,,,
    Sep 2009
    Audley STAFFS
    Default fuse/ electrical Q,,,,,
    I want to wire up a fag lighter/aux/ socket/ in the 04 1.8 vec, it MUST BE live WHEN THE IGNITION IS SWICHED OFF, Any idea if there is a fuse in the front left foot well that is live with the ignition swiched off,,, its to run a small scanner. thanks ANT.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Best thing to do is run a decent size cable through the loom grommet on the bulk head,and using an inline 10 amp fuse nearest to the battery,connect it to the battery,with a spade connector on the other end to the live part of the cig lighter/aux socket.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Aikon58 View Post
    OK thanks for the reply.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by CLOMP View Post
    hi clomp
    ive got one of these in the boot all the time check it out
    i love it
    http://www.halfords.com/webapp/wcs/s...1&iozone=PDPz1
    has your scanner got a cigarette lighter on the end
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    has your scanner got a cigarette lighter on the end?
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by vectra ste View Post
    yes it has at the moment,, your gizmo is a good tool but it seems a lot of dosh when a short bit of wire and a in line fuse would do me, but thanks for the thought.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    its a good bit of kit
    what type of scanner is it?
    Sep 2009
    Audley STAFFS
    it an old one realistic
    ,,,are you saying that I could run the scanner or a small electrical device of the jump starter/ inverter?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    : i run my laptop off it mains
    : to blow my tyres up i plug the machine in the cigarette socket {but you can in the car anyway
    : if you have a flat battery it can start the car up to a 5l engine.
    its up to 300w on the mains
    your scanner would be fine
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. electrical wire fuse
    Last Post: 2nd March 2010, 12:53
  4. electrical
    By leerawlings in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2010, 22:14
  5. electrical
    By lee324uk in forum Engine & Drivetrain
    Last Post: 1st December 2008, 09:34
