Thread: White smoke, oil leak, mayo
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Default White smoke, oil leak, mayo
    Had mayo round my oil cap for since i can remember tbh and i have always put it down to the very short journeys i do and only occasionally actually using my car. It does get rather thick tbh.
    Its never really worried me but MOT time is soon approaching and ive also recently noticed a fairly bad oil leak from what ive told is probably the rocker gasket and to make matters worse ive also noticed i seem to get a little white smoke coming from the exhaust even after driving for a while.
    Is the smoke and mayo anything to worry about? And is it normal for the gsi to have white smoke? I put it down to the cold weather but im not so sure? Will she be alright come mot time with that smoke? worried about emmisions
    I have no power loss atall btw
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Take it to a garage mate and get them to check fir hydrocarbons in your water, just to be sure, but sounds like hg failure to me
    Regular Member M65's Avatar
    Bolton
    Classic signs of HG failure.
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Sure hope not . Not lost a drop of water since i bought it tbh
    Bolton
    Coming from owning a Rover and then a Pug306, it all sounds too familiar Im afraid. My 306 did the same. It was fine for ages, in fact it didnt even have mayo under the rad cap. Still had the white smoke though and then things just went worse and worse. I hope its not HG too but it sounds very much like it Im afraid.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Sure the mayo in the cap is normal on the 3.2 if you have not removed the extension part of the oil filler tube. Read on here a couple of times its because its in the cooler air and causes the cooling oil vapours to turn to Mayo. Hopefully other 3.2 owners can confirm this for you. For piece of mind find a garage to do a sniff test on the coolant tank.
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    I've heard that too and has never really worried me too much as like i said, i only ever really travel short distances at a time (normally 8mile to my fiancees house). But worried about the smoke as originally i though it may just be the cold start but recently had a 200mile run and noticed it was still slightly smoking. Although as i said, no loss of water, or power
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Any info from other 3.2 owners?
    Feb 2011
    Suffolk
    Chuddy, a garage will check your coolant for peice of mind in minutes matey worth checking for sure no matter what anyone says on here chap, if its ok then worst case scenario aint gonna happen...
  1. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  4. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  5. White smoke!
    By stickygreen in forum Engine & Drivetrain
    Last Post: 1st February 2012, 19:02
https:www.vectra-c.comforumshowthread.php128852-White-smoke-oil-leak-mayo
