Results 1 to 10 of 19
Thread: Another jacking thread
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Another jacking thread
    Guys I know this has been asked before but I want to check something. I relize that there are four plastic blocks around the car to jack but these are mostly for locating the supplied jack. On looking though the other threads I see some ppl use wood cut to size in there and then a trolley jack but I would like to not use wood. So I think the other main jacking points on the front are just in front of those blocks and there is a hole in the middle of the flat section. Then just in front of the rear suspension arm there is another flat part with again the same hole. Are these the correct parts to jack on. As in where a garage would jack up on ( there is no way a garage is using the plastic blocks lol). Thanks again and yes I've used the search function and this is why I'm
    Asking. Thanks
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I use a flat piece of wood that sits in the cup of my trolley jack,and is the same size as the cup and put this under the plastic blocks to jack my car up,and it's fine.
    West Yorkshire
    I was expecting a car jacking thread!!!
    Aug 2007
    Lisburn, N.Ireland
    The part I'm talking about is the bit as in the pictures on this thread http://www.vectra-c.com/forum/showth...Jacking+points
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by aerodynamic18 View Post
    You will end up deforming that part of the under side of your car in the end and also scratch the paint off and cause it to rust prematurely in that area.
    Its perfectly safe jacking up on the plastic blocks.
    Aug 2007
    Lisburn, N.Ireland
    But is that not where a garage puts there 4 pillar lift points?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    That is where i put them when using a 2 poster ramp with 4 lifting arms.
    If it's good enough to take the weight of the car on the ramp,it's good enough for me to jack the car up using them,and if one breaks,they come out easy enough to replace.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    yes mate thay do bt there covered in rubber so no scratching unlike a jack
    Sep 2010
    in a box
    Quote Originally Posted by Aikon58 View Post
    yes but you must have very small ramp arms then or small lifting plates as i use the bits the op's on about with the hole in the middle lot safer in my book plus dont bend your sills
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i use the chassis leg at the front and the square jacking point at the back
  1. help with jacking the car up
    By carlsondavid33 in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 10:18
  2. Jacking points
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2009, 19:33
  3. Car jacking attempt...
    By blue estate in forum General Chat
    Last Post: 15th June 2009, 21:00
  4. car jacking
    By John35 in forum General Chat
    Last Post: 20th December 2007, 10:22
  5. Jacking alarm
    By caravaner-tony in forum General Chat
    Last Post: 6th September 2007, 12:28
