I have had to disconnect my radio CD30 as it will not auto turn off when i turn engine off ,take keys out etc,
Could something be shorting somewhere ?
Two items..
1) Have you turned off ignition logic in the settings... ?
If yes, then you need to turn the ignition logic back on.
2) If the ignition logic is still on, then there is a common fault on some CD30's, which turn themselves on, or refuse to turn off, resulting in a flat battery..
Not sure if it is the radio or display... think it is the radio.
Only fix is to get a replacement radio !! - Sorry !
Fortunately there are loads on Flea-bay..
For info - the wiring to the CD30's is the same across the whole Vauxhall range... BUT and this is a big BUT
The screens for the Vectra-C and Signum are the only screens wired up correctly...Corsa c / D or Astra H screens will not work in a Vectra-C
So do not get a matched pair from e-bay, you need a divorced radio. Unless from a Vectra-C
Hang on this there not a setting on the cd30 to have it auto-turn off? Maybe that just needs re-setting?
