Thread: Swirl valve bar off....
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Swirl valve bar off....
    I have noticed my swirl bar is laying on the engine will it be ok to be driven until monday when i can get it to a garage?
    What will my next step be to fix this? i just had it serviced and glow plugs were changed could it have been knocked off when they were doing this?
    john
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    they will drive fine with it off usually. get it changed though.
    Gazza4
    Aug 2010
    Thanks for the quick reply.. what will need to be changed? is this costly?
    Regular Member Craig1985's Avatar
    harwich essex
    Vauxhall will prob charge £800-£900 as it will need the new design inlet
    Aug 2010
    Ohhh dear..... its under warrenty but im not sure what i need to tell them? is this a wear n tear item or something that can just break?
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    Quote Originally Posted by johnnyboy1985 View Post
    It wont have been knocked off during the service or when changing the glow plugs. A new inlet manifold is the best fix and ive seen then on ebay for around £170 delivered, if you cant fit it yourself then labour costs on top of that.
    Try the £1 (HOW2) repair using tap washers, i did it with mine and its worked a treat and pushing on for 5000 miles now and still hasnt moved, its pretty easy to do..
    If its under warranty they probably wont do it under that, its a common fault but they will try and get you to pay if they can..
    harwich essex
    Should be covered under warranty. Just tell them car feels sluggish and you have noticed the bar off. I would be trying to get it done asap as you don't want to be footing the bill. I wouldn't say it's wear and tear
    Jan 2010
    stockton on tees
    Regular Member Jezzy's Avatar
    S.E
    It's not wear and tear, it's bad design by Fiat. Should definitely be covered by the warranty. Manifolds aren't supposed to wear out with age...
    Aug 2010
    Cheers guys...it states its covered in my book so hopefully should be fine
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
