Thread: 2.2SE Water in the engine oil?
    wales
    Exclamation 2.2SE Water in the engine oil?
    I have a 2003 Vectra auto with the 2.2SE petrol engine with nearly 90K on the clock.
    When I dip the engine oil I allways get a small amount of white sludge on the bottom of the dipstick. I have changed the oil and filter twice with recommended vauxhall synthetic oil but shortley after that the sludge returns. I have kept an eye on the water and engine oil levels in case the head gasket has gone but the levels are staying the same over 1000-1500 miles.
    Is there any kind of rescurculation system fault on the engine that will cause this to happen, or anything I can do? I have taken the car on several 1.5hr runs to just in case its just the short runs I do (about 20 miles a day). Any help would be appriciated.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    thats a wired one mate when you changed the oil and filter what colour was the oil
    wales
    It looked OK not sludgey at all, thats what I dont get
    wales
    Anybody have any ideas please?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    probably just condercation mate
    Wales, UK
    Think condensation build up on theses. It did on my Vec B Z22, although most common on the 3.2 I think. My head gasket did fail in the end however but did hold its coolant level well with the creamy stuff up untill that point. Maybe a good run and see how it looks ?
    Essex
    I wouldnt panic. I have a Vectra 06 plate 2.2 and i generally get the white creamy stuff on the oil dip stick/oil filler cap all winter it goes when the weather starts warming up. Smell of oil in the water bottle is the sign when the head gasket has gone.
    wales
    Ok Thanks for the replys. Ill just see how it goes, hopefully with no head gasket issues
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    I have a vec b with a z22se engine and they are prone to condensation. Later model vecs were fitted with the black plastic rocker cover in an attempt (so I'm told) to reduce the condensation problem. Just use the correct oil and try to give your car a good run at least once a month (100 miles-ish) and it will burn off / evaporate any water in the system, until you have to do it again lol!
    Perfectly normal, just check your oil and water for contamination every now and again, keep the engine regularly serviced and you should be fine
    hth
  1. Engine Fault Light - Water in Diesel Fuel Filter?
    By rharris21 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 10:06
  2. pin hole water leak in engine block !!!
    By bradie1974 in forum Engine & Drivetrain
    Last Post: 22nd September 2011, 18:56
  3. Oil in Water on Z20NET Engine
    By sjanisz in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 14:15
  4. Water Damaged Engine - Advice Please
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 11:50
  5. Engine sucked in water!
    By namtaffy in forum Engine & Drivetrain
    Last Post: 28th September 2008, 08:31
1.9cdti water on dipstick
how to stop condensation in engine oil vectra c
opel z22se white sludge
z22se creamy oil
https:www.vectra-c.comforumshowthread.php128822-2-2SE-Water-in-the-engine-oil
04 vectra 2.2 engine water in oil
signum 2.2 petrol oil creamy
astra 2.2 milky oil
gunk in oil vectra
