Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Custom Exhausts
    spoons
    Guest
    Default Custom Exhausts
    Hi All,
    I am thinking on fitting stainless steel custom exhausts once the VXR body kit is fitted next week....
    The guy reckons he will cut the old system off from the back of the Catalist and then fit a custom stainless steel twin exhaust system through to the tailpipes.
    He reckons that by not fitting back boxes, it will emit a nice 'sporty' tone without booming or blaring down the road.
    Now, it has been suggested by a friend that I would need to consider three things.
    1) Exhaust Warrantee (which I beleive is for 1 year from Vauxhall) and the car is 1 year old next month - so I'm not worried about this.
    2) Insurance - not a problem
    3) Back Pressure Sensitivity
    This back pressure sensitivity has caused me to speak with the specialist who explained that if the engine was naturally aspirated then it would be a problem, but, because I have a turbo then back pressure will not be a problem. (any comments.......?)
    These are the tailpipes (I've put a business card in front to give a sense of scale as they are much bigger than standard SRi ones.....)
    Here, there and every where!
    Tailpipes will fit ok as they look like 5x3's to me.
    As for not having rear boxes, i was only going to have the left side box replaced and a straight through pipe to the tail pipe on the right hand side. Looked silly as it looked odd but it might look ok with no box either side.
    I had my centre box replaced by a straight pipe with a box either side at the back. I was told this should keep the back pressure as close to standard as possible.
    All you can do is try it and see what it sounds (and goes) like
    you don't need the pipe "cut" at the cat end, becos their is a join their and is clamped..
    Those pipes look Fantastic.....
    spoons
    Guest
    Quote Originally Posted by armoured farmer
    you don't need the pipe "cut" at the cat end, becos their is a join their and is clamped......
    Thanks Micky.... 'cut' was my terminology.... but you know what he means...
    Once the VXR kit is in place, he will 'present' them against the car and see what we think...
    He offered them up to the car whilst it still has the standard SRi and it looked really good.... followed the natural line of the bumper as well which was nice....... but they are BIG in comparison.....
    Wink
    Is it the same VXR back end as i have? if so look here
    spoons
    Guest
    Is it the same VXR back end as i have? if so look here....
    Yep, thats the one.... VXR rear valance and VXR middle bit thingy.....
    The tailpipes that I will be getting look 'almost' identical to yours (what do you think) the profile seems the same....
    Very nice mate, it will look superb with those pipes,,,top man..
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Will look top if you ask me.
    I would ask for it to give you an idea on sound tho
    Leicester
    I would be very cautious about the lack of back box's to be honest, I have my own thoughts on these custom exhausts, personally I think only exhausts designed to fit a specific model should be used.
    But each to their own, but Spoons, your chosen tailpipes will look very good.
    Leicester
    Just had a look at the MIJ site Spoons, looks very good, from what I have seen, if anyone is going to make a good custom system, it looks like they could.
  1. Where to get a custom exhausts?
    By bizerk in forum Styling
    Last Post: 30th March 2009, 19:11
  2. Custom Exhausts In The South?
    By bigboynigs in forum Petrol Engine related
    Last Post: 17th November 2008, 10:49
  3. Custom Exhausts
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2007, 09:19
  4. Custom Exhausts.... Anyone?
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 22:04
