Results 1 to 2 of 2
Thread: ABS and ESP lights on
    Regular Member tox's Avatar
    Bucharest
    Trim : C
    Engine : Z19DT
    Unhappy ABS and ESP lights on
    Hello mates !
    For the last 2 days the abs and esp light came out on the dashboard. Switched the ignition off, back on, and they turned off after 2 seconds with a relay "clank" sound from underneath the dashboard.
    Yesterday it did like this 2 times, but this morning the lights remained lit, and no relay "clank" sound.Checked all abs fuses and esp fuses, all ok. Battery is good, started the car like a charm on -10 -13 degrees, but interesting thing is that, now it's not cold at all, like 4-5 degrees, read somewhere that a end life battery can cause the abs system to fail because it needs power to do the self tests. My car starts fine.
    Bucharest
    Trim : C
    Engine : Z19DT
    new info : i washed the car, thought one of the sensors was dirty,started the car,lights go off every time, and after a few seconds even if thr car is idle, the lights come on. I pushed the tc button to take off the system and something weird happened:
    When the abs light came up, my door closed and i heard a small bip , just half a second like it does when you forget the lights on and open the door
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
vectra c esp fuse
esp light on dash fuse vectra c
esp fuse vectra c
