Thread: 2.0DTi Fault Codes
    New Member martint's Avatar
    Feb 2011
    Littlehampton
    Default 2.0DTi Fault Codes
    Hi all
    I've recently joined the forum, and have OP-COM in the Littlehampton Area
    Car has been drinking a bit too much fuel for my liking lucky if I get 40mpg, going in for service monday and also to diagnose any faults.
    Anyway The car with spanner symbol came on the dash the other day and after running in Limp home mode, turned engine off and restarted seems to clear fault.
    I have just run OP-COM on car with no symbol on dash and the following faults are logged
    B3794-08 Switch Cruise Control Circuit Malfunction - Switch is intermittant not fussed really but is it easy to change switch?
    B3916-0F No Communication with Alarm Siren - ???
    B0283-05 Pane Break Open Circuit - Fuse is removed as last summer Alarm kept going off when very hot
    Just been out for run to induce fault so car/ spanner symbol on dash
    got home re ran OP-COM
    1 extra fault code now
    P0234-5B Boost Pressure Control Circuit Positive Deviation
    If any one could shed some light on the Boost Pressure code would be greatly appreciated.
    MT
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Cruise control - not sure on that one but could be something to do with the switch on the clutch?
    No communication with alarm siren - some people unplug the siren in the boot because it's pretty quiet. This forces the car to use the horn instead. Look in the left corner of the boot behind the panel and you should see the siren, sounds like it just needs plugging back in.
    Pane break open circuit - I believe the heater strips in the rear window are used to determine if the window has been smashed. If some of the strips are broken the alarm thinks the window has been put through. Got some bad heating elements in it?
    Boost pressure control circuit - try cleaning the boost sensor. It's a common fault on the DTi engines. Causes low power. Do you know where it is? Can be difficult to explain but there's pictures on the site in how 2's that you can see it in. Only takes 5 minutes.
    Feb 2011
    Littlehampton
    Thanks cont1204, not really fussed about the alarm and cruise control but the boost pressure sensor is a must fix will try and have a hunt for the pictures in the How 2's
    MT
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Here you go, found a quick photo thanks to Innes tutorial for boost pipes, hope he doesn't mind me borrowing it!
    Feb 2011
    Littlehampton
    Thanks cont1204
    sorry to be a pain but whats the big silver thing with the black tube just below?
    is that the EGR valve?
    will that have to come off to get the boost sensor out??
    sorry for all the questions but not really mechanically minded more electronic n computers.
    MT
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Ah bit like me then! But seriously this is a walk in the park. You'll need to undo the black hose and pull it off (well don't have to but allows for more movement) then undo the 4 bolts on top of the silver bit the black pipe connects to. Can then just undo the boost sensor and give it a pull - they seal in tight so they don't let air out so will need a bit of a tug to get it out.
    Yes that is the EGR but it doesn't need to be removed to clean the boost sensor. It does no harm to give them a clean up though.
    Feb 2011
    Littlehampton
    Hey conti1204
    think i have fixed the problem, found a thick rubber seal on the vac pipes that run to the componant behind radiator had a split in in not sealed at all just been for run and hey presto can't get it to fail and goin Limp home mode
    got the vac seal pipe from motor factors £3 for a metre
    I will get round to clean boost sensor and egr valve but not today as its raining
    MT
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by cont1204 View Post
    To remove boost sensor, just undo 1 bolt that attaches it to the silver thing. No need to remove the silver thing at all. Think the bolt is 10mm.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Graham View Post
    True but it can be a right sod to get to with it being 'underneath' the sensor. Means you can clean the throttle body up when it's off too.
  1. More fault codes 2.0dti
    By eddy931 in forum Engine & Drivetrain
    Last Post: 21st June 2012, 11:28
  2. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  3. fault codes
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 18:41
  4. Help with Fault codes
    By Rhbjones in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2010, 13:08
vauxhall vectra fault code b0283 alarm
B0283 - Pane Break Open Circuit
