Results 1 to 3 of 3
Thread: Intermittant limp mode....HELP!!
    Sep 2010
    Cheshire
    Default Intermittant limp mode....HELP!!
    Hi guys!! I own a 52 plate vectra c 2.0 DTI. Just recently, as i'm driving, the car will fall into limp mode and sounds like all boost is being vented too. But after a while, it will go normal. But then eventually revert to a point the engine starts dying!!
    I've tried cleaning the map and egr sensors....any other ideas what it could be??
    I was considering buying a tech 2 laptop-based scanner on the cheap.
    http://cgi.ebay.co.uk/OBD2-OBD-2-Tec...item4cf2fcfafe
    But is there anything I should consider before buying?? Do regular tech 2's work on half / full canbus cars?? Mine is half, but i'd like to know I could use it on a variety of others!!
    Nic
    lincolnshire
    try the vac pipes
    Sep 2010
    Cheshire
    [QUOTE=bembo449;1439186]try the vac pipes[/QUOTE
    ok.....also! Just downloaded free tech 2 to use with a compatable obd lead....
    Follow the above link and click on the download link at the bottom of the page. Save the file and unzip it to use. I'm gonna give it a bash later and get back with a seperate thread if its any good...looks like a basic reader at first glance...
  1. why does my eml come on and go off and go into limp mode?
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 13:48
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode!!!
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 14:20
  4. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
  5. Intermittant Limp mode
    By djr69uk in forum Engine & Drivetrain
    Last Post: 19th May 2008, 21:45
