Thread: help wantd plz
    Feb 2011
    leeds
    Unhappy help wantd plz
    hi all
    am new to the site and wanted some much needed help
    got a vectra 54 1.9cdti 120bhp changed egr (very cheap £68 genuine part) today and guess wot now i got the spanner light on and it throws alot of black smoke
    sum1 said its the inlet manifold but when i turn it off and start it again its ok but as soon as i drive its back on again and the car drives lumpy and alot of black smoke
    any1 help plz
    lost1
    Regular Member paul.sessions's Avatar
    leighton buzzard
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Was it doing it before you changed EGR ?
    Irmscher Insignia CDTI 130
    PRESTON
    Check the boost pipe for splits, particularly underneath and also check the thin vac hoses that run to the turbo control valve on the slam panel and make sure the boost sensor is clean. It sounds like it's overfuelling, so check these first before moving onto such things ae the intercooler or injectors.
    Feb 2011
    leeds
    thanks guys for the reply
    the car was running ok but ad the eml on i erased it then it went ape on me the code was p002279 egr so changed that and it then started with black smoke and limp crapp on me now ad a mechnic look at he saying inlet manifold or swirl things
    Feb 2011
    leeds
    Quote Originally Posted by paul.sessions View Post
    Feb 2011
    leeds
    hi big mac
    it was running ok but had the eml on i erased that which had a code of p002279 which meant change egr i did that then it startd with the rest black smoke and running lumpy in lower gears but took it for a very long drive that didnt help either now am going mad i will check the pipe work to see if theres any thing lose or craked
    Regular Member leonvectrac's Avatar
    south shields
    Welcome along
    Feb 2011
    leeds
    hi guys
    guess wot the black smoke was exhaust manifold gasket
