Thread: which brake pads for my 3.2?
    Oct 2009
    newport
    Default which brake pads for my 3.2?
    hi guys!
    im struggling to find the right set of front pads for my 2004 3.2-have alrady been sent 1 wrong set please help!
    These are whats on there at the moment :-)
    Regular Member Jezzy's Avatar
    S.E
    Work out from this what size your front disks are, and with that info motor factors should be able to match the pads to the disks.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    A 2004 model should have 314mm front discs and 292mm rear.
    Early ones, i.e. 2002 and some 2003 models had 308mm fronts
    S.E
    Quote Originally Posted by Hyperhart View Post
    Should have gone to specsavers...lol. As in the spreadsheet above, models up to a certain chassis number have 302s, the rest have 314. Vec-B's have 308.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The pads you have there are the same as fitted to mine - for 314mm discs. Mine are marked ATE as manufacturer.
    For the sake of anyone curious, the older type 302mm disc pads are roughly the same size as just the pad part of the 314 pad.
    Oct 2009
    newport
    cheers guys! can anyone recommend a fast supplier for these as i want to try to get them done early next week?
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Lol Jezzy, my GSi was registered 4th Jan 2004 and has 314mm fronts.
    Sorry, i'm sure that i read on here a while back that early 3.2's had 308's.
    Glasgow
    They have never had 308mm discs it was 302mm or 314mm.
  1. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  2. brake pads
    By HEP in forum Handling & Braking
    Last Post: 17th October 2008, 23:32
  3. brake pads
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 09:38
  4. brake pads
    By dwdwdw in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2008, 10:25
  5. Brake Pads
    By phildews in forum Handling & Braking
    Last Post: 15th July 2007, 20:06
what size brakes are on my 2004 3.2 gsi
