Thread: Changing Headlight Bulbs
    May 2008
    maidstone
    Default Changing Headlight Bulbs
    Any advice on how to change the headlight bulb on a 55 facelifted Vectra?
    Had a quick look and seems nigh on impossible to get my hand down due to packed engine bay!
    please advise!
    Wittsy
    PRESTON
    which side bulb are you trying to replace?
    May 2008
    maidstone
    the Nearside main beam bulb
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Check the How to, basically unclip and pull off screenwash filler tube, lift battery and fusebox cover, gives a bit more space. On driver's side taake complete airbox off, far easier.
    May 2008
    maidstone
    Cheers muchly!
    The How to???
    Is it fairly easy? I am complete novice!
    PRESTON
    i believe the only way to get to the main on a facelift is to loosen the bumper, then unbolt the headlamp to gain access. the dip can be done in the same way or by unclipping the washer bottle filler neck from the slam panel, then twisting the tube from the bottle.
    this might help http://www.vectra-c.com/forum/showthread.php?t=15060
    May 2008
    maidstone
    Cheers guys!
    might leave it to the dealer!
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by Grumpy1954 View Post
    Managed to do the dip on the drivers side without taking anything off...
    Tight but I managed it......
    Only got small hands....
    The main may be more difficult.....
    Barnsley
    i did is y day to fit hid,
    drivers side had to take air box off pass side managed with fuse box lid open
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. changing headlight bulbs
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2011, 22:27
  3. Changing NSF bulbs
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 22:26
  4. changing bulbs on front
    By astratovectra in forum Bodywork & Interior
    Last Post: 9th March 2008, 21:07
  5. Changing bulbs.....
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 14:30
