Results 1 to 3 of 3
Thread: Odd shaking - Am I going mad
    Northumberland
    Default Odd shaking - Am I going mad
    1.9 CDTI 150 2006. 56k
    First post from newbie!!
    1. Recently bought this from a main dealer but its doing things I'm not sure of. On start up the whole car moves as it fires. Not a transmission shunt. More like the engine moves and the rest of the car moves with it. Same when I switch off. Sometimes its not too bad.
    2. Possibly related. When in traffic (1st gear) and moving off, when lifting the clutch the there is a small shunt before the biting pont and when dipping the clutch it seems not to smoothly disengage all the time. If I move off in 2nd, which I had to in the snow I don't think I can feel it at all. It doesnt seem to do it on inclines
    I like to make smooth gearchanges but I'm struggling to make them all the time 1-2-3. 4-5-6 seems OK.
    Been to the dealer. 1st time they replaced 2 gearbox mounts which seemed to improve things a little. It went back on Wed and they said they can't fault it. Am I going crazy?
    I can't hear the symptoms of a DMF failure (peas in a tin when accelerating/clunk on stopping the engine etc).
    Has anyone any ideas??
    Cheers for any help
    Tim
    Northampton
    Engine : A20DTH
    Mileage : 88000
    See if you can get someone else to drive it and see if they get the same result. Sounds like Clutch/DMF which should be replaced at the same time and under warranty. Can you find out from the dealer if it has been done before?
    Northumberland
    Thanks man,
    I'v taken off the beauty cover and started it while looking at the engine and theres a fair amount of movement while starting. A little bit while
    How many mounts are there on the engine and transmission?
    Tim
  1. Car / engine shaking
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2016, 19:14
  2. Engine Shaking the whole car
    By inchy1981 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 14:34
  3. shaking whole car
    By alijlacy in forum Vectra C / Signum Troubleshooting
    Last Post: 15th December 2010, 17:20
  4. Shaking 3.2?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th September 2008, 08:03
  5. shaking at idle
    By POAH in forum Engine & Drivetrain
    Last Post: 19th December 2006, 08:10
